No high beams! Help!
Postby Toyotaguy » Mon Aug 10, 2015 1:30 pm
High beams do not work. Fog lights flash to pass and low beams do all work just standard high beams the inside indicator does come on when I switch to high beams but the lights don't and the fog lights do not turn off.
Toyotaguy
Re: No high beams! Help!
Postby fussellbug » Mon Aug 10, 2015 6:35 pm
Based on the wiring diagrams, I would say the most likely causes are the combination switch itself or bad contacts in the wire connector to the combination switch. Pull the switch and look for dirty or corroded connections. If you don't find anything wrong at the connector, try to locate a used switch from another Celica.
fussellbug
Images: 36
Postby Toyotaguy » Mon Aug 10, 2015 6:44 pm
Found the problem. The contacts inside the switch weren't making a connection. Tweaked the contacts and shes good to go. Thanks for the feed back.
Toyotaguy
