Looking for System 10 radio
Postby LvX » Tue Apr 19, 2016 6:56 am
hello everybody, i'm looking for a system 10 radio (86120-33110) anyone has one to sell?
LvX
Re: Looking for System 10 radio
Postby alltracman78 » Tue Apr 19, 2016 8:11 pm
I've got one. I'll try to check the part number tonight?
Postby alltracman78 » Thu Apr 21, 2016 1:29 am
Sorry, mine is 86120 2b290.
I believe they're generally interchangeable. How many connectors/pins do you have on the rear of yours?
Postby LvX » Thu Apr 21, 2016 6:11 am
HI!
thanks for checking, this is mine:
https://i.ytimg.com/vi/oiATUSj_1t0/maxresdefault.jpg
and here you can see the connector:
http://www.aliexpress.com/item-img/TOYO ... 3135.html#
my radio is not amplified and it needs the system 10 amplifier to work with
LvX
Postby 93celicaconv » Sat Apr 14, 2018 10:54 pm
alltracman78 wrote:Sorry, mine is 86120 2b290.
alltracman78, do you still have your Toyota P/N 86120-2B290 available?
I believe this part number is for a 14-pin wiring connector at the back. I don't know if it has the diversity antennae connector at the back in addition to the primary antennae connection, or just the primary antennae connection. I also don't know if it has the steering wheel control connection at the back or not.
If yours has the diversity antennae connection and the primary antennae connection, and the 14-pin wiring connector, and if everything on this unit is in excellent working order, let me know if you still have it and want to sell it. I may be interested.
93celicaconv
