Power window auto up
Postby LvX » Wed Jul 27, 2016 9:01 am
Hi all,
i'm trying to get the auto up of the driver window working in my st185, after disassembling the button housing it seems clear that the auto up is available but just blocked.
here a few picture:
as you can see in the bottom contact there is a blocking piece of plastic, i've removed it with a cutter
then to have the button make the "double click" , you should trim the plastic with a little rasp here:
then you need to add two diode:
ah, and while there you could change the green led for a nice blue one, it' s a normal 3mm one.
LvX
Re: Power window auto up
Postby ChrisD » Wed Jul 27, 2016 3:41 pm
Enabling the auto-up was one of the first mods I did to my car! Good stuff.
1988 ST165
1994 ST205 WRC
ChrisD
Postby underscore » Mon Aug 01, 2016 3:01 pm
Is there a way to disable it? If I remove the diodes will it stop doing it? My car has this and it drives me nuts. I want to see if I can make the passenger window auto down though.
Postby LvX » Mon Aug 01, 2016 3:54 pm
definitely removing the diodes will stop it, but why?
it does a double click if you don't push it too far it will not go auto..
as for the passenger side there is no way of doing it it miss the relais.
LvX
Postby underscore » Mon Aug 01, 2016 5:55 pm
I hate it, I'm not sure what was done in my car but it's damn near impossible to have the window at anything other than fully open or fully closed. If I want it open partway I have to look like an idiot with my window flying in different directions until I get lucky and it just stops the movement instead of changing the direction.
Postby LvX » Tue Aug 02, 2016 5:26 am
It should have a double position, first it goes up and down freely than if you press it further there is a second click and it goes auto. It seems that you miss some spring in yours, anyway you can totally remove the auto feature desoldering one wire of the solenoid from the board.
LvX
Postby bitter » Tue Aug 02, 2016 5:27 pm
Cool mod. You should sticky this in the how-to's. What's the spec of the two diodes.
bitter
Postby underscore » Tue Aug 02, 2016 5:31 pm
LvX wrote:It should have a double position, first it goes up and down freely than if you press it further there is a second click and it goes auto. It seems that you miss some spring in yours, anyway you can totally remove the auto feature desoldering one wire of the solenoid from the board.
Good to know, I'll pop it apart and see if somethings amiss.
Postby FC Zach » Tue Oct 17, 2017 7:13 am
I just did this modification to a spare switch of mine. Not knowing what size diode to buy I just recycled some from a scrap computer.
These visually looked the same, maybe slightly smaller. . what's the worst that could happen if not the proper size? ?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby LvX » Tue Oct 17, 2017 11:01 am
any diode will work except a zener, the current is really low beacause it only triggers the relay
LvX
Postby FC Zach » Tue Oct 17, 2017 1:37 pm
Well. . It didn't work and smoked on top of that. I did exactly what was written above. Maybe I used the incorrect diodes? Either way, I don't think I'll be risking another switch.
FC Zach
Images: 9
Postby LvX » Tue Oct 17, 2017 4:51 pm
what smoked out? post a photo it did work for me
LvX
Postby FC Zach » Wed Oct 18, 2017 2:55 am
What I've seen so far. There could be an underlying issue that caused these. I'd be willing to try again but on a spare. Next time I'll use new diodes.
Burnt tracer:
Overheated/Cracked thingamajig:
FC Zach
Images: 9
Postby LvX » Wed Oct 18, 2017 7:01 pm
i think the problem is the diode you used, change them to black ones (normally the zeners are all made of glass) if you have it and repair the track with a bit of solder.
you can avoid burning another time by measuring resistance with a multimeter between the power pins or by placing a bulb in series with the power supply and checking if it light up.
LvX
Postby FC Zach » Thu Oct 19, 2017 4:11 am
LvX wrote:any diode will work except a zener. .
LvX wrote:i think the problem is the diode you used, change them to black ones (normally the zeners are all made of glass) if you have it. .
I'm confused. . what did you use? Isn't that what you have pictured?
LvX wrote:then you need to add two diode:
FC Zach
Images: 9
