ST205 EWD
ST205 EWD
Postby plaidward » Wed Feb 01, 2017 5:32 pm
If someone has an ST205 EWD (electrical wiring diagram) please let me know.
Even better if it's a pdf and you can send it to me.
I've found some links online, but they all seem to be too old and don't work anymore.
plaidward
1989 Toyota Corolla
Re: ST205 EWD
Postby GT4_DRED » Wed Feb 01, 2017 8:37 pm
plaidward wrote:If someone has an ST205 EWD (electrical wiring diagram) please let me know.
http://gt4.mwp.id.au/.. He's also a member on this board.
'88 ST165 - project "Rahtid"
'91 MR2
GT4_DRED
Re: ST205 EWD
Postby plaidward » Fri Feb 03, 2017 3:04 pm
I used some of his info for my project already, but none of that is an EWD.
Here's a couple examples of EWD's. Each system is mapped out with connectors, pinouts, junction blocks, and what harness the systems go through. In the 90's toyota even showed the harnesses in vehicle with where the connectors resided. Check out the second link and go to "Electrical wiring routing". You could build a harness with one of these if you needed to, which is what I need to do...
http://freewiringdiagram.blogspot.com/2 ... agram.html
http://bgbonline.celicatech.com/90ewd/index.html
plaidward
1989 Toyota Corolla
Re: ST205 EWD
Postby MWP » Fri Feb 10, 2017 4:42 am
You can pay a small amount of money to get most of them here: https://techinfo.toyota.com
