slow to respond tachometer
Postby celicadude93 » Sat Nov 04, 2017 2:22 pm
Just curious if anyone has come across this problem. I noticed the other day that the tachometer is very very slow to respond. I know about what rpm about i should be at going certain speeds and accelerating etc... but the tach never reaches where i should be and is just sluggish to do anything. Wondering if you guys think it's more of a cluster issue or sensor on the trans issue. any feedback is appreciated. Thanks
1990 celica alltrac (restored)
2005 toyota 4runner
1990 celica alltrac (daily driver, trusty rusty)
celicadude93
Images: 13
Re: slow to respond tachometer
Postby JRWperformance » Sun Nov 05, 2017 5:44 am
The tach gets the signal from the ignition/ECU. Might have some crunchy solder joints in the cluster. I've fixed a few things on my 165 by reflowing and adding good solder to the pins in the cluster and my climate control. Just reflow everything your soldering iron can touch. Over time, the solder joints can develop little cracks. Reflowing fixes this. It might help your dash.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
Postby celicadude93 » Sun Nov 05, 2017 12:54 pm
JRWperformance wrote:The tach gets the signal from the ignition/ECU. Might have some crunchy solder joints in the cluster. I've fixed a few things on my 165 by reflowing and adding good solder to the pins in the cluster and my climate control. Just reflow everything your soldering iron can touch. Over time, the solder joints can develop little cracks. Reflowing fixes this. It might help your dash.
Thanks! I'll look into doing that over winter
2005 toyota 4runner
celicadude93
Images: 13
Postby yyonline » Sun Nov 05, 2017 10:31 pm
There are 2 capacitors on the tach that like to die: viewtopic.php?f=49&p=465638
yyonline
Postby celicadude93 » Mon Nov 20, 2017 12:06 am
yyonline wrote:There are 2 capacitors on the tach that like to die: viewtopic.php?f=49&p=465638
Thanks man! I think that's exactly what the problem is. I will head to my local electronics store and pick up those parts and complete that repair. The description is exactly what mine is and plus it gives me the excuse to change the bulbs out to leds.
2005 toyota 4runner
celicadude93
Images: 13
