A
Anonymous
Guest
I know it's pretty straightforward to install a voltmeter with just a positive and negative wire...
I didn't really want to run a wire into the engine bay though...
I have read that you can get the source from the fusebox.
I tried various fuses such as radio, IGN, ECU/IGN< and still don't get a voltage reading...
I am going to check my ground but the gauge is lighting up so I assume it's partially working just not a strong enough ground to read voltage :shrug: ..
Anyone have any suggestions ???
