12V ignition source help still needed after search
HoleShot
New member
I am installing an intercooler fan in my st185.
I've already searched the forum for this.
I have the main power source hooked up via the 100 amp fuse in the fuse box. I am using a relay to run this so I need a 12v ignition source. Everyone seems to say to look in the fuse box for ring connectors, but the only ones I've found are the 100 amp constant source ones.
I am hoping to get a source closer to the firewall on the driver's side, if anyone has any input please let me know.
Gary
Moderator
There is a splice point on the ignitor wire.
It's black-orange wire on my 1993.
It's the E9 in the picture.
Use volt meter to confirm this.
HoleShot
New member
Thans gary, once again you come through for me.
Fan is installed and running. Man that thing is pretty loud!
Top
