klue":1gsd6chf said:i was planning on buying a TWM shifter for my car, but i ended up just taking the black extension of the stock shifter, gives much better feel but the throw is still long. I am on a budget so its good enough for now. After i did the mod it took SO MUCH effort to shift, i would push to the right and it woulnt spring back to center itslef if u know what i mean. But now its fine, i guess it just took a while to reseat itself properly and move the grease i put on into the bearing cap.
alltracman78":35iyezd1 said:Did any of you have studs instead of bolts holding the plastic piece on?
I couldn't use the supplied spacers 'cause I have studs, and they're too short. :x
I stuck some thick washers in there for now. I guess I'll have to cut the studs out one of these days.
Also, the plastic balls were too small inside for the TWM shifter. I had to dremel out the inside a slight bit.
Anyone else have this problem?
gpmarzan":3b6lm92w said:Sorry for bringing this topic back, but I just had to add that yea I think that the twm shifters are cut too low. My arms arent that long and I hate having to reach down to grab the shift knob. I shouldve never hacked my ae92 corolla short shifter from ebay im using now for my st165. Might not be as short of a throw and better quality than the twm but its better than stock and it still has a long shaft so that you wont have to reach down, while still having a shorter throw. I might just go and buy another one on ebay.
