Switch to full style
Post a reply
JDM Power Folding Mirror wiring (for future reference)
Fri Jun 10, 2005 4:41 am
Ok I just finished this and I'm pretty much too tired to label all of it, but here's the gist of it:
For those that have the set, just match up your colors to the diagram. This diagram, of course, assumes you're using ST185 mirrors, and also assumes you have the relay, the kind with 11 wires. The top cluster is your switch, the bottom middle cluster is your relay, the right cluster is the mirror (wire harnes & mirror wire colors), and the left cluster is the left mirror. It's right. It works. Save this in an archive so anyone else who asks can be done with it. I'll add any explanations when I get back into town. Enjoy.
D
P.S. I know little to nothing about electrical wiring or diagrams except what I've learned from this and other forums, so I apologize if this diagram isn't up to electrician spec, or whatever.
power folding mirrors
Tue Jun 14, 2005 5:16 am
Hey, thanks for the diagram....i just got my hands on some jdm folding mirrors today off a 1992 JDM Celica, and it came with the relay and such, so this is a big help!
Thanks, GaryMD
Tue Jun 14, 2005 3:15 pm
Another recent discovery:
If you notice, the set up requires two positive inputs (grey & blue/yellow) and one ground (white/black). I've found that if you pop out the middle vent piece, you'll notice that there are four wires going to the clock. One is green. Forget that one. The other three, however, are white/black (ground), grey (15A Cig/radio), and blue/yellow (20A dome). The grey you don't have to worry about since that's coming from the switch, which is already wired in the USDM cars. But for the white/black and blue/yellow, the clock is a great place to splice the connections to the relay. If you get some of those wire tap-ins available at radioshack just splice from the blue/yellow and white/black wires on the rear of the clock and you can probably also stick the relay back there. There's enough space for it. I haven't actually done this myself, since I haven't had the time to get it all done, and because I want to have the wires going from the mirror into the door harness to go through the wire loom, so it's not a big homemade-wiring-job mess.
I think what I'm going to do for that is take the stock 3-hole terminal cover off of the harness end of the mirror wires, and put the three wire terminals into the 7-hole jdm terminal cover. Then leave the outer 4 (2 on each side) wires coming from the jdm terminal cover, and try and run those through the existing loom, but the space in the loom is already pretty tight, so I'm not sure how I'm going to do that exactly.
Once the wires are through the loom and under the dash, there are 4 empty holes in the blue connector (IC1) which I'll use to keep everything neat. From there, run to the relay behind the dash. This all seems to make sense in my head and on paper, but we'll see how it plays out in reality. I mean, it'll be functional, but as far as fitting everything and making it look pretty, that part's still up in the air... or on the floor of my basement as the case may be.
D
Tue Jun 14, 2005 3:17 pm
Sorry, session timed out. Last poster was me.
D
Mon Dec 26, 2005 12:48 am
Ok i got some mirrors for Christmas today and that diagram is right for my mirrors but my retract control and switch have different number of wires and colors, So I am posting some pictures of the switch and box to show how i did the diagram I will also post.
Tue Dec 27, 2005 5:25 am
can anyone out htere post the stock power mirror diagram please?
Tue Dec 27, 2005 6:20 am
are those pictures of your stock mirror wiring, or the stuff you just got? I'm wondering, because I have the same problem, although it may be opposite of you.
Tue Dec 27, 2005 6:45 am
the pictures and diagram are of the stuff I just got.
Tue Dec 27, 2005 2:18 pm
maroon_185 wrote:the pictures and diagram are of the stuff I just got.
Your stock switch, what does the plug look like underneath it?
Tue Dec 27, 2005 4:32 pm
It looks nothing like that one, it goes stright in and uses flat pins instead of round like the JDM switch I have. here is a picture
edit: can someone look up this part # and tell me if I have the right retract control 85964-20020
Sat Dec 31, 2005 6:27 pm
Hey can you post a picture of the switch itself? That connector is really strange. I'm wondering if someone got you the 4th gen or 6th gen set up. That would explain the differences. Very strange.
Sat Dec 31, 2005 6:48 pm
the switch looks exaclty like the stock one except with the retract button off to side
Sat Dec 31, 2005 6:50 pm
maroon_185 wrote:the switch looks exaclty like the stock one except with the retract button off to side
My current JDM switch looks like yours, although the last set of folders I owned had a switch that exactly resembled your stock one. Basically, we need to know the pinouts of the flat style switch, and we can do another diagram.
Sat Dec 31, 2005 7:49 pm
that would be helpful for hte switch but my retract control box is still short a wire, and has differnt colors
Sun Jan 01, 2006 1:19 pm
Attempt to post pinout without having to send pictures
I have electrical books for both 90 celica and 90 alltrac, here is
what both have for stock remote control mirror
Switch
1..2.....tab......3
4..5....6.....7...8
SW-1=GR (goes to 15A cig&radio in fuse block)
SW-2=LG-R (spliced and goes to pin 2 of both mirrors)
SW-3=W-B (earth,ground)
SW-4=not used
SW-5=LG-B (to RH mirror, pin 3)
SW-6=LG (to RH mirror, pin 1)
SW-7=BR-Y (to LH mirror, pin 3)
SW-8=BR-W (to LH mirror, pin 1)
Post a reply
