Wiring in portable MP3 into System 10
Postby Stubble » Wed Sep 01, 2004 2:02 am
I've got a portable MP3 player (flash card) that I want to wire into my System 10. I'd like to have one end of the wires loose with a stereo mini connector, so I can just plug in the player when I need to. Where should I wire in the preamp signal? Looking at the wiring diagram, it looks like I have to split the signal to the 4 channels (FL,FR,RL,RR) and run these to the amp. Also, how would I tell the system 10 that I want this extra input? I could put a blank tape into the deck, but I'd still get noise.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby Gary » Wed Sep 01, 2004 2:13 am
Your MP3 player has speaker level output, not a preamp output. You will get lot of noise trying to amplify it with the System 10 amp, which takes preamp signal. However, you can do it with "line output converter". It converts speaker level to preamp level.
To make thing easier, you can just use this:
93 ST185
Gary
Postby Stubble » Wed Sep 01, 2004 8:55 pm
I can use the speaker level into my home theater receiver through any of the RCA pre-amp inputs in the back (such as CD or AUX), and the sound is pretty good (ie not too much noise). If it works on the home theater, will it work with the system 10?
How good does the tape input sound? I had thought of that, but didn't think the sound would be any good. Maybe it would still be better than running into the sys10 pre-amps?
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Postby Gary » Thu Sep 02, 2004 2:14 am
I honestly don't know the answer to your first question.
For the quality of the tape input, it sounds pretty good, but will not sound perfect as the CD. However it will save you a lot from headache splicing the wires under the passenger seat. Give it a try.
93 ST185
Gary
Postby Stubble » Thu Sep 02, 2004 2:49 am
Deal. Thanks for the idea.
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
