A
Anonymous
Guest
need some help with the wiring for the power windows in an st165. my p/s window wont go up but does go down. does anyone have the wiring diagram of the power windows... thanks :doh:
My experience when this happens is that it's the window switch, not the wiring. Get another p/s window switch and you should be good to go.Anonymous":3mkaveab said:...my p/s window won't go up but does go down. Does anyone have the wiring diagram of the power windows...
That tells me it's 99.9% the p/s switch. Test the continuity; a visual won't tell you much in this case. The wiring for this hardly ever goes bad. and the d/s switch shouldn't affect the p/s switch.903SGTE":nekslkv7 said:I took apart the p/s window switch and cleaned all contacts and it all looks good but the window won't go up. If I put power to the motor it works up and down. Could it be the d/s switch causing the p/s switch to not get power?....
