Antenna Problems.
Antenna Problems.
Postby PaulN » Mon Sep 06, 2004 6:59 am
Hi
Ive got a Celica Gt 1994, the Auto Antenna is playing up and as a quick fix i want to simply disconnect it. Theres 3 possible ways:
1) At back of the Head unit. Will have to take the centre console out.
2) At the Antenna motor. Im struggling to get to the motor quickly.
3) Along the wiring in between the Head unit and the motor? Does anyone know where the cable is (ie fed down passenger side Uk car). This would be my best option.
All i want is to stop the Antenna trying to come up when the sterea is on.
Thanks
PaulN
PaulN
Postby alltracman78 » Mon Sep 06, 2004 10:47 am
There's a wire from the headunit that powers the antenna. You'll have to cut that. Best bet is the rear of the headunit, or at the antenna.
Postby PaulN » Tue Sep 07, 2004 6:43 am
Thanks for that info. Any ideas of the size, position and colour of the wire coming from the head unit?
PaulN
PaulN
Postby alltracman78 » Tue Sep 07, 2004 2:50 pm
On the 5th gen it's a blue wire coming off the headunit. Not sure on the newer ones.....
Postby Guest » Fri Sep 10, 2004 5:45 pm
ugg dont we all have antenna problems...
Guest
Postby kolb » Tue Oct 12, 2004 7:57 pm
i need celica 10 speakers system wiring diagramm. power antenna diagram to install the power antenna (another car) can anyone help me
kolb
Postby zblu81 » Wed Oct 13, 2004 2:33 am
the antenna on the fifth gen can just be unplugged at the base, no need to cut wires
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
3" Exhaust, RC intercooler, ATS TD06-20g, stage2 clutch
zblu81
Postby Guest » Thu Oct 14, 2004 3:48 pm
How to take the hold antenna assemly off from the rear. Cause mine broke and need to put new ones.
Guest
Postby MARLON1211 » Thu Oct 14, 2004 3:51 pm
Anonymous wrote:How to take the whole antenna assemly off from the rear. Cause mine broke and need to put new ones.
SO BE IT
MARLON1211
