SuperWhite92":ljiuaspa said:After installing both, I'm 90% sure they're the same.
What would make you want the 92 instead of the 90 version? After installing them, they both sit at the same height.
I edited the title to lessen any confusionCMS-GT4":17mgtou9 said:EDIT: n/m, I thought we were talking about stock shifters....
silence":1jtp8gje said:SuperWhite92":1jtp8gje said:After installing both, I'm 90% sure they're the same.
because i can get a 92-93 for cheap...but I have a 90...so i'm wondering if a 92-93 will work on my car.
daveryan":43nma6v9 said:I seem to remember the two nylon cable bushings that pop onto the stick itself being different sizes and non-interchangable.
I tried putting a 93 stocker in place of my 90 stocker and since I didn't have the 93 bushings (oops!) - it couldn't be done.
The TWM I have requires you to transplant these bushings onto their shifter, so the ball ends that these pop onto would have to be diff sizes for 90-91 and 92-93.
That makes me worry a bit. When I installed a friend's 91 TWM, we used the bushings from my stock 92 shifter, since we cracked one of his trying to get it off. They snapped on and everything.
