First Day at the strip
Postby CodingParadox » Sun Mar 12, 2006 4:25 am
I went down to the dragstrip for the first time ever today, to see what I could do with the trac. My radiator had started leaking from the endtanks a few days ago, after a hose popped off on the dyno, so it was leaking. I quickly started having overheating issues, but I still got 4 runs in, then gave up due to overheating and not wanting to damage my motor. I went over to a friend's house and he gave me his old aftermarket GTS radiator, which is actually thicker than the stock AT radiator, so I'm using that for now. For the first time in a while, I seem to have no coolant leaks!
My best run was only a 13.5@105mph. Hmm. I'll take a pic of the timeslips later tonight. I should be at least a full second faster than that, and really should be more than that.
The track was cold, which didn't help traction - I also had too much air in the tires, which didn't help either, but that shouldn't have taken that much off my time. I still only trapped at 105mph, which is indicative of another problem elsewhere.
I'm running the HKS SSQV BOV, but I still had to mostly spool back up between shifts, even though I was shifting what I thought was pretty quickly. I'm gonna try switching back to the short shifter tonight, I think. I'm just wondering if the BOV isn't hooked up to a good enough spot to keep the turbo spooled at 24psi between shifts...
I'm also going to try to install a launch control cable today so I can keep my foot floored between shifts, as well as to help with launches.
Then I'll decide if I wanna go back and drag some more tomorrow. :)
CodingParadox
Postby klue » Sun Mar 12, 2006 6:18 am
when something is spinning at 100k rpm, it tends to slow down pretty quickly. making 24 psi lol its not going to hold that for long without a large air flow, what does the boost drop down to after shifitin?
Postby SeanGTS » Sun Mar 12, 2006 7:38 am
Very cool nonetheless :) We'll have to hit it up again tomorrow if the weather prevails :D
Master Swapper
SeanGTS
Postby toayoztan » Tue Mar 14, 2006 2:06 am
Have a picture of your timeslip? I'm very curious on the stats of your run.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby sleeper » Tue Mar 14, 2006 3:20 pm
if you have 392awhp you shuld be able to trap close to 120mph!
so either it`s something wrong with your car or you suck at driving! :)
sleeper
Postby Conan » Tue Mar 14, 2006 7:07 pm
I'd like to post my favorite:
Are you sure it was 392WHP not flywheel HP? :)
Conan
Postby CodingParadox » Tue Mar 14, 2006 8:38 pm
Conan wrote:I'd like to post my favorite:
Yes. :P
The turbo was pretty much completely despooling between shifts, so I was shifting too slowly. In addition I was having overheating issues that I didn't notice until after a few runs, so it's possible I 1. my HG is now leaking, or 2. the EMS was pulling power+timing due to high coolant temps.
In any event, I hooked up the launch control cable, and have been playing around with using that. That should help a bunch for between shifts, as well as I'm gonna switch back to the short shifter.
Yeah, I know I should be closer to 120mph. :P
CodingParadox
Postby Celi-GT4 » Wed Mar 15, 2006 2:12 am
Keep working at it. Drag racig comes with practise. How are your 60fts? Try no to let off 2 much during shifts and let the clutch eat. I ran my times in Kansas with the stock GTS 2k tires on backwards so the tire issue should not kill you. It's the launch, if you run a 2.0 60ft and then run a 1.80 you will trap like 8 miles faster. Keep practicing, also what was you SAE corr on the dynojet?
12.4 @ 115mph Topeka Kansas NA2005
12.2 @ 109mph blew HG Moroso 1/08
Sold out, now on stock 3rd gen
Blitz ecu, dp,exhaust, tien ss, carbon driveshaft,light wheels/brakes,os giken twin plate
Celi-GT4
Postby CodingParadox » Wed Mar 15, 2006 2:15 am
SAE corrected was the 392whp. Yeah my 60ft times were around 2.2, so I'm still working on that. Launch control should help.
Edit by KORacing: 392whp was with STD correction and in 2wd mode.
CodingParadox
Postby Griffin » Wed Mar 15, 2006 5:15 am
That MPH is way low regardless - you should be in the 110s or 120s at least. Something else is wrong besides just the launch and shifting speed.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby Celi-GT4 » Wed Mar 15, 2006 8:48 pm
Coding I realize that is the sae corrrected, I am wondering what the correction factor was (ie .102 or 1.18 etc). By pulling a 1.8 60ft I bet you would see nearly .8sec of the ET.
Todd
Celi-GT4
Postby RedCelicaTRD » Wed Mar 15, 2006 9:18 pm
You where at PIR, right? Did you happen to see a white Supra there?
Postby CodingParadox » Wed Mar 15, 2006 10:10 pm
No, I was at woodburn, but the white supra was there.
The correction factor was only like 1.02. It was 389whp uncorrected and 392whp corrected.
CodingParadox
Postby SeanGTS » Wed Mar 22, 2006 4:22 am
I still think you should of forgotten about the whole burn out thing. My instructions were pretty clear, to just a quick chirp in the beginning of the day to clean them off.
Next time, skip the AWD burnout, its killing your 60 foots.
Master Swapper
SeanGTS
Postby CodingParadox » Wed Mar 22, 2006 4:37 am
I think the launch control will help more. Holding 9psi at the line is kinda nice. :)
CodingParadox
Return to Racing Chat
