15.7 and 2nd pass (now with vid!)
Postby etantshi » Tue Jun 06, 2006 5:25 pm
I didn't slam the gears, but there wasn't much slack. You can hear my BOV in the vid to see the shift points. (also the blown struts allow you to see the car lurch when I shift)
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby alltracshoak » Tue Jun 06, 2006 6:26 pm
where's the vid at?
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby etantshi » Tue Jun 06, 2006 9:07 pm
The first post. I edited it to include a link to the vid.
André B.
etantshi
Postby Conan » Wed Jun 07, 2006 5:45 am
Man, that was no launch at all :twisted:
Conan
Postby etantshi » Wed Jun 07, 2006 3:31 pm
The next run has a better launch with lower 1/4 mile time.
2nd run
R/T.... .510
60 ..... 2.179
330.... 6.523
1/8 ... 10.132
MPH... 68.19
1000.. 13.231
1/4.... 15.889
MPH... 83.64
André B.
etantshi
Postby Sleeka_89 » Wed Jun 14, 2006 11:07 am
How many runs down the quarter did you do before the run in the video?? Is you clutch on the way out or was is just really hot cause you were slipping quite abit in second gear by the sound of things, thats probably why your 60 footers are all that flash either and thats probably where your lost time is. Smashing the gears abit harder would help ya alot. Just think if you can change .1 of a second quicker each gear... it all adds up to a better time.
A man who shoveled snow for an hour to clear a space for his car during a blizzard in Chicago returned with his vehicle to find a woman had taken the space. Understandably, he shot her.
Sleeka_89
Postby jlspec » Thu Jun 15, 2006 2:53 pm
Your 1/8 is a little high. I ran a 9.7 with only a exhaust.
jlspec
Postby RafaCalde » Thu Jun 15, 2006 3:13 pm
even so man. all the stuff you have done to the car should more than make up for poor launches and blown struts. i average 15.4@89 in florida heat and humidity
r/t - .719
60' - 2.135
330 - 6.284
1/8 - 9.706
mph - 71.65
1000 - 12.648
1/4 - 15.123
mph - 91.11
this was my best run ever this past april with track temp at like 75 with high humidity. all i have is a gutted CAT, ghettofied 3" exhaust, MBC spiking 15 lbs running 11 constant, and a ACT street kits(ACT plate and OEM disc). that's also with the spare and various other crap that was in the car plus i weigh 300 lbs.
Rafa
RafaCalde
Postby Simba » Fri Jun 16, 2006 2:24 am
Judging by the cloud of gray smoke coming out the back, you're either running pig rich or nuking your clutch.
That's very slow for the level of modification. What kind of boost were you running?
Lots of fast, loud things.
Simba
Postby etantshi » Sun Jun 18, 2006 5:28 pm
I have an autozone stock clutch. My spec stage III grenaded itself.
I think it's a decent run... I mean I have a super restrictive exhaust (it is literally crushed next to the x member), and I run super rich on the top end. The g-force ecu is tuned for a T67 with 550cc injectors.
André B.
etantshi
Postby Simba » Tue Jun 20, 2006 2:42 pm
etantshi wrote:I mean I have a super restrictive exhaust (it is literally crushed next to the x member), and I run super rich on the top end.
That'll do it. Fix those issues and you'll go a lot faster.
Simba
Postby 2of81 » Sun Aug 06, 2006 10:15 pm
etantshi wrote:r/t....................696
60....................2.276
330..................6.577
1/8...................10.088
mph.................71.26
1000.................13.098
1/4...................15.700
MPH..................86.28
I have a vid that I'll post soon.
Yea it's in the launch, my bone stock car ran a 2.09 60' with a 15.58 @ 85.69 mph...Your MPH is a hair higher than mine stock...so that tells you where you are in HP about the same
Justin
1972 Corolla TE27
2of81
Postby TheAutoholic » Mon Aug 07, 2006 12:58 am
Try your next run with an open dp, and see what that gets you. If you really think you are losing that much power with the exaust problem, this should help. Then we can go from there.
Currently All Trac-less....
Dracov wrote:I'm firmly convinced GT-Four trannies are made from collapsed stars.
TheAutoholic
Postby 2of81 » Mon Aug 07, 2006 4:26 am
TheAutoholic wrote:Try your next run with an open dp, and see what that gets you. If you really think you are losing that much power with the exaust problem, this should help. Then we can go from there.
Also on top of that a correct A/F ratio tuning would go far from there! I know André will get it all done right before it's all said and done.
Justin
1972 Corolla TE27
2of81
Postby TheAutoholic » Mon Aug 07, 2006 5:41 am
Yeah, he needs a friend with a wide band.
TheAutoholic
Return to Racing Chat
