***UPDATE***Ran a 13.5 @102 mph!!***VIDEO***
Postby silence » Thu Oct 12, 2006 12:28 pm
I went to moroso last night, and my best time was a 14.1 at 96.52 mph. I have room for improvement because my 60' was 1.93. If i can get that down to 1.8 or 1.7 i think i can run high 13s. THis is all at 15lbs of boost with a ct27 and supporting mods.... Overall i'm pretty happy.
What other 60' times have you all seen run with an alltrac?
06 WRX, 90 Celica Alltrac & 88 BMW TURBO 325is
http://www.youtube.com/watch?v=Ei5P9LfLRdg
silence
Postby Gary » Thu Oct 12, 2006 1:12 pm
Nice number Carlos. Avg, 60' time from http://www.gtfour.ca/race.html is 1.9857 ,not counting the FWDs and Pat's
93 ST185
Gary
Postby omgitsroy326 » Thu Oct 12, 2006 2:42 pm
what are supporting mods?
omgitsroy326
Postby silence » Thu Oct 12, 2006 4:16 pm
omgitsroy326 wrote:what are supporting mods?
Built motor CP pistons ARP everything
TRD head gasket
Removed-ported TVIS
ATS high pressure fuel regulator with walboro 255 pump and stock 440s
CT27 with ATS ROM tuned to run 17psi (i was only running 15psi)
Custom front mount with straight intake.
Clutch masters stage 3 with fidanza lightweight flywheel
Aussie d-pipe and midpipe with hks 2.5 rear section.
No ABS Airbag or AC. Full interior.
silence
Postby omgitsroy326 » Thu Oct 12, 2006 4:42 pm
torque?
it just seems that you should be hittin way better numbers...
your 60' is good... iono... seems like you're losin power in the middle.. i'm not doubin your drivin skills.. jus seems like you should have more juice with those mods
especiall ct27 +rom tune
omgitsroy326
Postby silence » Thu Oct 12, 2006 5:27 pm
Honestly I had trouble with bogging on the launch. My best run was the last run of the night. I'm pretty confident i can get a 1.8 60' which should put me in the 13.8 range. My air fuel was at 10.6 at WOT, so I am also able to safely raise the boost another 2psi which could give me mid to low 13's. We'll see.
The car has power, i just need to work on launching it. Its quicker than a stock STi from a 60mph roll
silence
Postby Klas » Thu Oct 12, 2006 6:12 pm
Nice run, but I think you can hit high 12 pretty easy with you mods (simular to my car).
I launch at 6000 rpm Meet up the trottle fast with the cluch but do not "side step" the clutch.
And if you can run on let say 102 octan fuel and advance the timing a few degrees, you will be running high12s. I´m positive!
Nice work!
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby omgitsroy326 » Thu Oct 12, 2006 6:35 pm
yea.. with those mod.. i was thinkin low 13 / high 12
omgitsroy326
Postby silence » Thu Oct 12, 2006 6:36 pm
Gary wrote:Nice number Carlos. Avg, 60' time from http://www.gtfour.ca/race.html is 1.9857 ,not counting the FWDs and Pat's
thanks for the link gary
silence
Postby silence » Thu Oct 12, 2006 6:39 pm
omgitsroy326 wrote:yea.. with those mod.. i was thinkin low 13 / high 12
yeah that would be nice...but it was my first time at the track...in any car. I usually stick to autox and track days.
With more practice, i should be in the 13s...12s is a strech
KLAS
BTW What does it mean to side step the clutch?
silence
Postby Klas » Thu Oct 12, 2006 6:51 pm
Having the clutch pressed down then just move you foot to the side of the pedal. that´s side step. do not do this, that´s bad for the drivetrain and couses the engine to stall at the launch. Just practise will help. practice allot! I´s all about timing. release the clutch at an even pase, quick but do not "side step". hard to explane but you will get the hang of it. Hope you understand what I´ve writhen. My english aint the best.
Now on youtube!
Klas
Postby GT4times2 » Sat Oct 14, 2006 6:12 am
Jose,
You should have told us. Long time no hear. Pretty decent run btw. Let's try to go in December when it's cooler, and see what times you get. I was there 2 Fridays ago. Let me know when you're going again. Gary, are you up for it?
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Postby silence » Mon Oct 16, 2006 5:54 pm
Frantz:
Its Carlos btw :wink:
I'll let you guys know the next time I head up that way! Im hoping i'll be in the 13s.
Do either of you know of a place where i can get my rear diff oil changed, and one of my driveshaft U joints replaced?
Gary:
How was the Miami auto show? I was not able to make it down:( I had a visitor from out of state.
silence
Postby GT4times2 » Mon Oct 16, 2006 6:18 pm
Im sorry, why did I write Jose, when I was thinking Carlos? :doh: I apologize.
I will check for you. I know of a shop that handles that. I think it's the Driveshaft shop in Ft Lauderdale. I will ask and get accurate info, and relay it to you. I will ask my friend. You can also check out the guy that did my swap. He's at ease with Alltracs and MR2s, owned a few himself. He's also affordable. Let me know which way you want to go with that.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
GT4times2
Postby silence » Mon Oct 16, 2006 8:53 pm
No worries,
Im open to either go to a shop, or let your buddy do it since you say he can handle it. If you could give me the contact info for both, id really appreciate it.
thanks
silence
Return to Racing Chat
