1/4 Mile again... this time with video
Postby Sleeka_89 » Thu Oct 26, 2006 7:29 am
I thought i'd take the celica down for another run last night, see if i can get my 12 second pass. It didnt happen though... :(
Best time was 13.08 at 110mph with a 2.197 60 foot time. The track wasnt prepped the best but that was mainly because 2 cars spilled fluids everywhere that night. I'm gonna go down this sunday because theres a big comp on and hopefully i can get more traction with a better prepped track. Anywho hes some footage of the run :D
http://www.youtube.com/watch?v=b-ypfitbfYE
A man who shoveled snow for an hour to clear a space for his car during a blizzard in Chicago returned with his vehicle to find a woman had taken the space. Understandably, he shot her.
Sleeka_89
Postby alltracshoak » Thu Oct 26, 2006 7:51 am
is your an alltrac/gtfour or an halftrac? if awd, how you do burnouts?
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby alltracshoak » Thu Oct 26, 2006 7:53 am
n/v, after reading some of your posts, i assume its a st162.
current:
90 st185
GT4 AWD
alltracshoak
Postby Sleeka_89 » Thu Oct 26, 2006 1:21 pm
hahahah yep st162 it is...
Sleeka_89
Postby vip09 » Thu Oct 26, 2006 2:39 pm
Nice! You need some meatier tires :)
vip09
Postby Mafix » Thu Oct 26, 2006 5:59 pm
13.08!! awesome time...what launch rpm did you use?
Postby 90TURBO4WD » Thu Oct 26, 2006 6:51 pm
nice run
get those tires to bite and you will be in those 12's :shoots:
90TURBO4WD
Postby vip09 » Thu Oct 26, 2006 7:59 pm
what are the specs on your car?
vip09
Postby Griffin » Thu Oct 26, 2006 8:48 pm
Great time!
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby Conan » Fri Oct 27, 2006 7:39 am
Man, replace those pimp wheels with some slicks! :P
Conan
Postby Sleeka_89 » Fri Oct 27, 2006 9:08 am
hahaha yeah its not so much the tyres (there only kumo estas 215/45 r17 though) but its the open diff gearbox that kills me. Every now and then during a burnout it will spin two but it will always only do a single pegger launch :x
Normally on the drag strip i try to launch at 3500rpm but feather it a little bit so it doesnt bog down. It normally gets off the mark pretty well but its when i snap second gear that it hurts my time. I smash it abit too hard and it just spins, if i was more gentle i might of done abit better. Oh well thats what this saturday is for, the track is gonna be prepped for 9 second cars so it should be sticky :D
The main reason i'm not running slicks (even though i've got a spare set of rims in the garage) is theres a magazine here called HPI that lists the top 10 street driven FWD, RWD and AWD cars in Australia and i want to get a high twelve so my car can be apart of that FWD title but slicks arent allowed. Only if MR2 gearboxes werent so expensive :cry:
Sleeka_89
Postby Sleeka_89 » Fri Oct 27, 2006 9:12 am
vip09 wrote:what are the specs on your car?
ST162 with 2nd gen 3SGTE, 3inch dump and mandral exhaust with hks cannon and hiflow cat, ebay manifold, mircotech lt8s (tune still in the low 10 afr :( ), ct20b turbo at 17psi, 600X330X100mm cooler with custom piping, pod filter with 3inch intake, blitz bov. So its just bolt on stuff, the motor, head, injectors, and h/g is all stock (also got a walbro fuel pump)
Sleeka_89
Postby Mafix » Fri Oct 27, 2006 9:13 pm
so like 2.2 lbs more boost than me, second gen to my first, and EMS...time to hit the dyno for me...i really should be a mid 13...gota hit the trac too. awesome info though.
Postby Sleeka_89 » Sat Oct 28, 2006 1:04 am
Mafix wrote:so like 2.2 lbs more boost than me, second gen to my first, and EMS...time to hit the dyno for me...i really should be a mid 13...gota hit the trac too. awesome info though.
yeah i would think mid to low 13, depending on the launch. When i used to have the ct26 i was running 15psi, everything else was the same and i did a 13.3
are you running a lsd mr2 box or a camry box?
Sleeka_89
Postby Mafix » Sat Oct 28, 2006 9:08 pm
neither 3sfe box with the upgraded syncros.
Return to Racing Chat
