Mods to reduce quarter from stock
Postby TRDking » Mon Feb 26, 2007 2:18 pm
Hello,
I am fairly new and was looking at buying an alltrac and was just wondering what mods would be needed to reduce your time on the quarter mile in a st185.
They run 15.7 stock dont they.
What is needed to run low 15s, 14s, etc.
If it had an exhaust/intake what would it pull
Thanks
TRDking
Postby alltracshoak » Mon Feb 26, 2007 4:09 pm
stock with a manual boost controller may be able to let you runs 15 flat.with a good launch and good driving, you should be at high 14s from my experience.
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby CDN-GT4 » Mon Feb 26, 2007 5:23 pm
On how much boost. I ran a best of 15.7 last season on my all stock alltrac. I've just installed an mbc so I'm curious as the first race of the season is in a month.
alltracshoak wrote:stock with a manual boost controller may be able to let you runs 15 flat.with a good launch and good driving, you should be at high 14s from my experience.
CDN-GT4
Postby alltracshoak » Mon Feb 26, 2007 5:29 pm
i ran with 12-14 psi.(just at the limit of fuel cut). i also have a act clutch which grabs better off the launch. i also have a home made exhaust muffler which doesnt effect anything because piping is still stock.i ran high 14s with just a mbc. best time was 14.8
current:
90 st185
GT4 AWD
alltracshoak
Postby lumbercis » Wed Feb 28, 2007 9:37 pm
Get a two-step. And lose weight.
lumbercis
Postby rallyst165 » Thu Mar 01, 2007 2:35 am
I ran a 14.1 with Intake, 2.5" straight pipe w/gutted stock cat, and a mbc at 15psi. I also have a act clutch and an hks flywheel. I'm pretty confident it would of ran high 13s with a downpipe, but I spun a rod bearing before I could find out.
Joel
Hillsboro, Oregon
89 st165 w/185 motor
85 mx73 cressida
92 sc300
86 Ae86 Stage rally car
Joel@dirtydrifters.com
rallyst165
Postby CDN-GT4 » Thu Mar 01, 2007 2:36 pm
Hmm, I can make up an intake pretty easily and I have a 2.5" KO downpipe in my closet awaiting install. I supposedly have a Zoom Stage 1 Clutch. With my mbc and some exhaust work, it should make the car fly!
rallyst165 wrote:I ran a 14.1 with Intake.....
CDN-GT4
Re: Mods to reduce quarter from stock
Postby 1BADGT4 » Sat Mar 10, 2007 12:57 am
TRDking wrote:Hello,
I am fairly new and was looking at buying an alltrac...
Thanks
Welcome. First step should be preventative maintenance/ full tune-up.
With those ONLY two mods ... you're looking at high 14s.
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
Return to Racing Chat
