what do you think?
what do you think?
Postby alltracst185 » Thu Apr 19, 2007 3:22 pm
i'm going to race a 1996 civic hatch with a 1995 gsr engine swap(u.s spec).my question is do you think i will beat him?i just have to put my greddy boost cut contoler in and maybe a jdm ecu for more agressive maps.(more hp)what do you think.
alltracst185
Postby TheAutoholic » Thu Apr 19, 2007 3:48 pm
When I had my swap finished last July I raced an EK hatch with a a GSR swap with CTR cams. My T-vsv was unplugged and I stayed even with him at 5 pounds from 20 to about 70. 8)
At 12 psi you should pull him unless there is more done to this car.
Currently All Trac-less....
Dracov wrote:I'm firmly convinced GT-Four trannies are made from collapsed stars.
TheAutoholic
Postby alltracst185 » Thu Apr 19, 2007 4:06 pm
(TheAutoholic )when you say swap done do you mean rebuild or did you put a 3sgte in a fwd celica?and what does unpluging the t-vsv do,where is it at in the engine bay?
alltracst185
Postby jlspec » Thu Apr 19, 2007 4:15 pm
If he's just a stright swap you could beat him dragging only. I've beaten my share of swaps at the 1/8 drag strip enough. My car is stock.
jlspec
Postby TheAutoholic » Thu Apr 19, 2007 4:20 pm
alltracst185 wrote:(TheAutoholic )when you say swap done do you mean rebuild or did you put a 3sgte in a fwd celica?and what does unpluging the t-vsv do,where is it at in the engine bay?
I have a second gen 3S-GTE in an ST165. The waste gate on the stock turbo is set to 5 psi. The T-vsv is the stock boost controller and it turns boost up from 5psi to 7 psi in (i believe)3rd 4th and 5th gears only. And I don't where it is in a ST185 engine bay. Since you have an after market boost controller don't worry about the T-vsv anyway.
TheAutoholic
Postby Conan » Thu Apr 19, 2007 4:28 pm
TheAutoholic wrote:it turns boost up from 5psi to 7 psi in (i believe)3rd 4th and 5th gears only
It's from 7 to 10-11 psi ;)
Conan
Postby TheAutoholic » Thu Apr 19, 2007 4:53 pm
Maybe on a Euro spec CS it is. On a USDM All Trac its from 5 to 7. 8)
TheAutoholic
Postby Conan » Thu Apr 19, 2007 5:31 pm
TheAutoholic wrote:Maybe on a Euro spec CS it is.
They all have the same TVSV.
TheAutoholic wrote:On a USDM All Trac its from 5 to 7.
Section 5 of Turbocharger System in 1990 Celica Alltrac / 4WD Repair Manual (RM149U) states:
5 psi is more like a fart than boost :twisted:
Conan
Postby Gary » Thu Apr 19, 2007 5:44 pm
In 3rd gear, no MBC, I get 7 psi when my T-VSV is capped.
10-11 psi when T-VSV is fully functional.
93 ST185
Gary
Postby TheAutoholic » Thu Apr 19, 2007 7:21 pm
Gary wrote:In 3rd gear, no MBC, I get 7 psi when my T-VSV is capped.
Isn't it defferent in a 93?
My motor/ecu is from a 90. As far as I have heard it should be at 5 with the T-vsv unplugged, and 7 with it working properly.
TheAutoholic
Postby Conan » Thu Apr 19, 2007 7:50 pm
TheAutoholic wrote:As far as I have heard it should be at 5 with the T-vsv unplugged, and 7 with it working properly.
You just don't give up, do you? :D Do you have a boost gauge?
Maybe what you heard is that the wastegate starts to open at 5 but opens fully only at 7? :shrug:
Conan
Postby jlspec » Thu Apr 19, 2007 10:58 pm
Not to sure what everyone else boost but my stock US-Spec 185 boost 5-6 psi 1&2 gear and from 3rd up it's 9 psi and then slowly drops as I speed up and the turbo is no longer needed. I understand stock it's suppose to boost 10psi but with heat and age I think 9psi is good. How do I know this, I've tried two different boost gauge with the same results. My car runs perfectly to know my knowledge and it idles perfectly even after a hard run.
jlspec
Postby CSAlltrac » Fri Apr 20, 2007 12:21 am
While we are on the subject, will it hurt me to discard the vsv?I did away with my t-vis and i was going to leave out the blue vac tank, the vsv, and the third one that is on the same bracket.I do have a HKS MBC.Any input is greatly appriciated
Postby alltracst185 » Fri Apr 20, 2007 11:38 am
i don't have a mbc anymore and i still get 12 psi or more sometimes.i have 3" exhaust with no cats and stock manifold,anyone know why this happened?
alltracst185
Postby Conan » Fri Apr 20, 2007 12:10 pm
alltracst185 wrote:anyone know why this happened?
Welcome to the world of boost creep :)
Conan
Return to Racing Chat
