Post your quarter mile times here!
Postby lumbercis » Thu Apr 26, 2007 5:48 am
Please post and encourage everyone else to post their quarter mile times for their GT-Four (all gens). The list is located on Chris Dittrick's site here:
http://myautosphere.com/home/modules/al ... view&cid=1
The submission system is automated so you can submit your own times. Certain times will require a timeslip to allow submission.
You are also encouraged to make a post with your time, pics/vids and any details of the run here in the racing chat section for discussion.
This post will be updated with any changes to the database and/or submission guidlines.
Happy Racing!
J.
lumbercis
Postby alltracshoak » Thu Apr 26, 2007 1:07 pm
14.8 stock with mbc set 12 psi and a ACT clutch
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby CDN-GT4 » Thu Apr 26, 2007 6:18 pm
15.702 stock st185
CDN-GT4
Postby Klas » Fri Apr 27, 2007 2:19 am
Ok,I´ll give it a try. 12.577s 176km/h with stock fuel and ignition system, stock ecu, ct26 (upgraded), Stock interior.
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
http://www.youtube.com/watch?v=hSD6LlwS830
Klas
Postby EVcelica » Sun May 13, 2007 6:42 pm
^^^ Post your mods not your NON-mods.
13.8 at 101 mph - stock head - stock turn signals - stock shifter - and stock paint (upgraded)
Erik
red 90 st-185
ct-20b, 3" exhaust, custom intake, fmic,
"THE" system
2005 Scion Tc "release series 1.0"
EVcelica
Postby andycaca » Mon May 14, 2007 7:24 am
13.1@104 (near enough)
mods:
straight intake with cone filter
FMIC
3" aussie downpipe
2.25" scorpion stainless steel full exhaust system
13.1@104mph - bonestock :)
andycaca
Postby CodingParadox » Tue May 15, 2007 10:17 pm
12.98@106
Stock longblock, SB46@22psi on race gas, super conservative tune. I threw out the timeslip, I was just curious what the car was doing. :)
CodingParadox
Postby Denver_whiteST185 » Wed May 16, 2007 5:00 am
19.664 @ 65.98 mph, I win slowest :D
Ive got the timeslip to prove it. The story behind it was that i had to sit on the starting line for 5 minutes or so since the mustang i was lining up against was having some sort of problems. I was also on my old clutch. The short of it was that i heatsoaked really badly, and then the clutch was slipping horribly. Now both the clutch and the intercooler are upgraded along with some other mods, so i expect low 15's at least this year, maybe high 14's.
btw, im located at 5280 ft.
^Ted^
Denver_whiteST185
Postby andycaca » Wed May 16, 2007 8:53 am
Gary wrote:
andycaca wrote:13.1@104 (near enough)
http://andrewmcc.com/13.1.jpg
mods:
FMIC
3" aussie downpipe
Did you forget something?
I meant a lot of things that did not come stock on your car. :wink:
im not sure what you mean? i have lots of other mods but they arent relevant to drag times. eg rollcage, big brakes, 16" wheels etc. boost on that run was 1.18bar btw
andycaca
Postby Gary » Wed May 16, 2007 9:39 am
mods:
FMIC
3" aussie downpipe
How much does your car weigh? :)
How about clutch, gearbox, diff?
I bet they aren't stock ST165.
93 ST185
Gary
Postby andycaca » Wed May 16, 2007 11:40 am
doh! youre right :oops:
ST205 gearbox and diff, fensport/helix 6-puck clutch. 1345kg fully loaded, without me in it
sorry :)
andycaca
Postby ChrisD » Wed May 16, 2007 3:28 pm
Hey guys!
To make things easier please provide me with:
1/4 slip (jpeg image...very important for validation)
Real Name (or the name you'd like me to use)
Year and Model of Car
Picture of Car
Mods list
Date of run
Thanks!
1988 ST165
1994 ST205 WRC
ChrisD
Postby lumbercis » Wed May 16, 2007 6:14 pm
I havent talked this over with Chris, but just to encourage everyone to keep posting, I think temporarily, we can go ahead and post you up until the next time you get to the track (and save your timeslip!).
As a temporary guidline, lets use the same standards that mr2oc uses:
Times of 13.00 don't need a timeslip, but it is highly encouraged!
Times of 12.99 or quicker MUST have time slip!
Photos of the car and videos of the run are highly encouraged.
Times of 11.49 or quicker MUST have time slip
and one of the following (Photos of the car are highly encouraged):
*official race results on 3rd party site (i.e. NHRA, NDRA, etc)
*video of the actual run or video of another run within .3 of new post
*already on the registry with a legitimate, established entry within .3 of new post
Lets see how this works out and we can make modifications later if we need to.
I'll edit the initial post with this info.
J.
lumbercis
Postby KORacing » Sun Jul 01, 2007 6:54 am
Owner: Trevor Johnson
Boardname: tjdouble07
Car: 1990 Toyota Celica Alltrac "Christine"
Relevant mods: 2.2L stroker, CP pistons (8.5:1), Carillo rods, OS valves, 272 HKS cams (110LC intake, 109.5LC exhaust), custom intake manifold, Ford TB, FMIC w/ 4" thick core, stock ignition, Accel plug wires, NGK iridium plugs (1 heat range colder than stock -- .022 gap), ARP head studs (standard 10mm), TTE 1.4mm head gasket, head/block lapped to 600grit with KO's Sonic lapping tool, Ported stock exhaust manifold, KO Racing Street Brawler GT35R w/ .63 A/R turbine housing, KO Racing custom exhaust, KO Racing custom 2.5" aluminum IC pipes, Tial BOV, ACT 6 puck clutch, Hydra Nemesis tuned by Kris at KO Racing, KO Racing 8mm bored stock rail (dual feed), Sard 800cc injectors, Aeromotive FPR (55psi static), walbro fuel pump.
Pic of Car: http://www.koracing.net/galleryimages/TJ007_GT4_20.jpg
Date of Run: 06/30/07
Timeslip: http://www.koracing.net/galleryimages/T ... 7_1187.jpg
Video of run: http://www.koracing.net/viewclip.php?clip=36
Kris/Lilly Osheim
KO Racing, Inc.
www.koracing.net
MR2 Turbo "Loki" -- 11.1 @ 128mph
Hydra Nemesis EMS PnP Exclusive distributor for 3SGTE Celica Alltrac/GT4
Certified Hydra Tuner -- I will travel to tune.
KORacing
Postby zak062 » Wed Aug 29, 2007 4:09 am
hks intake, blitz BOV, open DP
best run
r/t .053
60 '2.449
330 6.878
1/8 10.508
MPH 68.59
1000 13.553
1/4 16.158
MPH 86.05
Click here to watch alltrac-14--1
The stupid a$$ before me used 2 inch piping when he did the BOV.... besides that i dont know why my time is so bad....
03 Subaru wrx(DD) My first non-toyota
91 Mr2 #2 (sold)
91 Mr2 (Sold)
08 Scion TC (Sold)
88 alltrac, blue (Project)
89 CBR 600F Sold
91 Celica gts Sold
90 Celica gts Sold
[img]http://img263.imageshack.us/img263/3199/zac062copyto3.jpg[/img]
Finaly got an all-trac :)
zak062
Return to Racing Chat
