Just Began in lapping... any tips to keep my DD in shape?
Postby camry90 » Tue Jul 17, 2007 3:43 am
today, i did 2X20 mins of lapping. the car behave better than i thought and my new BF g-force sport tires helped a lot compare to the crap tires i had before. i need to upgrade my front brakes ASAP. for 20 mins, i was from 4000-6000 rpm. the engine didn't overheat; the needle stayed in the middle. but like always, i find that my underhood temperature is WAY too high. i don't have a number for you but it's hotter than other turbo cars... is tha normal for GT-four? i can't even imagin what it would be with out the RC hood...
i'm afraid for overheating creeping up on me... any tips?
camry90
Postby Denver_whiteST185 » Tue Jul 17, 2007 4:11 am
you can wrap your headers and your downpipe, or if you really want to do a good job, remove them and have them ceramic coated. also, if your still running a stock downpipe, the primary cat tends to collect alot of heat. ko racing makes a nice downpipe thats already ceramic coated and gets rid of the primary cat.
^Ted^
Denver_whiteST185
Re: Just Began in lapping... any tips to keep my DD in shape
Postby eddie_gt4 » Tue Jul 17, 2007 4:22 am
camry90 wrote: (...) i find that my underhood temperature is WAY too high. i don't have a number for you but it's hotter than other turbo cars... is tha normal for GT-four? i can't even imagin what it would be with out the RC hood... (...)
it seems to be a normal behaviour of a ST185 :|
if you still have the underhood insulation, remove it ASAP
'90 Toyota Celica turbo 4WD ST185 - ex
'96 Toyota Celica GT-Four ST205 - now
eddie_gt4
Images: 11
Postby etantshi » Tue Jul 17, 2007 7:10 pm
The ceramic coating does little or nothign on these cars. I had my manifold and exhaust housing sent to swain for their 'performace coat' and after I removed the parts for a motor swap, if found some of the coating had melted off. That's right melted. It get's that hot. The wrap will probably do better. In addition, remove any unnecessary crap from the engine bay to help flow. Lastly, upgrade the coolant system as much as you can (lower tstat, better fans, better rad, better fluid, sprayers if you want to go hardcore).
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby camry90 » Wed Jul 18, 2007 2:04 am
etantshi wrote:The ceramic coating does little or nothign on these cars. I had my manifold and exhaust housing sent to swain for their 'performace coat' and after I removed the parts for a motor swap, if found some of the coating had melted off. That's right melted. It get's that hot. The wrap will probably do better. In addition, remove any unnecessary crap from the engine bay to help flow. Lastly, upgrade the coolant system as much as you can (lower tstat, better fans, better rad, better fluid, sprayers if you want to go hardcore).
who makes thermostats for our cars? i seriously can't find any online. what kind of rad frluid should i go with? motul is good or oem Toyota?, i have a bottle of water wetter in my intercooler... that enough?
camry90
Postby Denver_whiteST185 » Wed Jul 18, 2007 2:48 am
trd makes a 160 degree one that ive been running, but unless its instock they take around 6 weeks to get them from japan. i got mine through burien toyota. ATS racing also makes a 170 degree one, but ive heard mixed reviews on them and the fact that they don't flow as much as the stock ones.
i would also run water wetter in the radiator. i know big power supra's run 20% toyota red coolant, 80% water, and a bottle of your favorite brand water wetter. Design engineering inc also makes a lot of "stay cool" products.
^Ted^
Denver_whiteST185
Postby camry90 » Wed Jul 18, 2007 4:42 am
Denver_whiteST185 wrote:trd makes a 160 degree one that ive been running, but unless its instock they take around 6 weeks to get them from japan. i got mine through burien toyota. ATS racing also makes a 170 degree one, but ive heard mixed reviews on them and the fact that they don't flow as much as the stock ones.
and the cool thing it's that i'm sponsored by DEI lol
what do you guys thing about running at 14 psi and water injection for 10 mins non stop? with a BIG water tank in the trunk
camry90
Postby Denver_whiteST185 » Wed Jul 18, 2007 5:03 am
I would not rely on water injection to help since it can sometimes fail. a larger reservoir up front for the intercooler will help defiantly, or do put the pump into constant run mode so its always switched on if you haven't already.
Another thing that will help significantly will be an external oil cooler. the reason why is that the oil is currently cooled by the engine coolant. that obviously puts extra heat and duty on the coolant system. taking out the stock oil cooler and running an external fin type cooler will help keep the oil cooler, and also put less strain on the stock cooling system. there are a few downsides with this, like your car will heat up slower when its cold out, there will be additional oil in the lines so you will have to change your oil a little more regularly, and you will need to make sure there is a thermostat so that the oil won't flow to the cooler if the oil is not above a certain temperature (since its your daily driver). there are sandwich type adapters or oil filter relocation kits out there. the only kit ive seen installed is maxspeed kit i believe, but you can make your own kit too. ko racing or speed source might be able to source you some fitting, lines, cooler, adapters, etc.
^Ted^
Denver_whiteST185
Postby AWDios » Wed Jul 18, 2007 6:17 pm
Also if you're just lapping and not really getting times, or racing etc. Drive a little less hard, obviously still have fun, but you don't have to go all out all the time.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby Balagast » Wed Jul 18, 2007 7:48 pm
Have you tried putting some washers on the hinges for the hood, I put like two thick at each to lift the back up and it definitely helped a bit for underhood heat
1990 All Trac - Red (Down but hopefully not out)
Balagast
Postby camry90 » Thu Jul 19, 2007 2:31 am
Denver_whiteST185: thanks for all your expenation. i will try out to change to oil cooler... you can just take out the OEM one and put a sandwich plate?
AWDios: there's time attack i want to attend as well
Balagast: i think the vents on the hood is enough. plus i hate the look. thanks anyway
camry90
Postby haireball9 » Thu Jul 19, 2007 6:29 pm
I have had good success with Redline Waterwetter in my Toyotas. Even my 162 seemed to have alot of heat compared to other cars. Toyotas seem to make alot of heat
http://www.redlineoil.com/products_coolant.asp
88 Alltrac
Supra Kid 95: i'll let you drive my alltrac
haireball9
Postby camry90 » Tue Aug 07, 2007 12:35 am
come pictures from the trac
camry90
brake sux!
Postby camry90 » Tue Aug 28, 2007 5:02 am
i got Dot 4 superblue fluid, hawk HPS pads and mountain rotors. after a few rounds, the pedal feels spongy and takes a lot more to stop. i think it's brake fade.... would it help if i change to SS hoses all around? i had SS hoses on my 240sx before and didn't see big difference on the street.
what pads are the best for lapping? EBC redstuff? portfieldR4S? does HAWK make HP+ for single piston ST185? what's the parts number?
any suggestions?
camry90
Postby RedCelicaTRD » Tue Aug 28, 2007 1:56 pm
Stainless lines will help with feel, but if you are getting fade it wont help. You need larger rotors/calipers that can handle more heat if you really want to combat fade.
Return to Racing Chat
