New 12sec pass
Postby illGT4 » Wed Nov 03, 2004 3:58 am
wow, good numbers for such little modifications.
good work.
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby ChrisD » Wed Nov 03, 2004 5:23 am
MrWOT wrote:I couldn't help but notice the fastest American ST165 on the list is only in the 14's :?
True. Perry B. and Omar are probably the fastest but they don't give me time slips. :(
I just received an email from an ST165 owner in Sweden. Fastest ST165 now is 12.23 seconds... :D
1988 ST165
1994 ST205 WRC
ChrisD
Postby LechacZ » Wed Nov 03, 2004 10:41 am
Hey Chris,
I was running same exact setup as on the dyno!
The guy who owned the dyno said that everybody complains that his numbers come up lower than every where else, he did say that with the numbers car pulled on his dyno i should be able to get it into high 12s...
Les
ST-205
Ontario, Canada
LechacZ
Postby enzytebob » Wed Nov 03, 2004 12:38 pm
Excellent result! :shock: Well done! :)
Probably makes sense for me to just toss out my gen2 and shoehorn a gen3 into my engine bay!
enzytebob
Postby Toby J » Fri Nov 05, 2004 6:14 am
can you tell me more about the launch control device? i've heard of that feature existing on certain aftermarket ecu's, but you say the original GT4 ecu is still in use? any ifo you can provide would be great.
Toby J
Postby LechacZ » Fri Nov 05, 2004 10:42 am
it's a bike rev limiter. http://www.accwhse.com/dyna.htm
I think i have the Dyna Standard REV Limiter, not sure cause i bought it used and they dont have my model anymore but the unit in the pic looks axacly same as mine
Its adjustable so i can set the rev limit to what i want.
it cuts out the ingnition at set RPM to keep that RPM and I used the clutch swith to turn the module on, other wise its bypassed
Les
ST-205
Ontario, Canada
LechacZ
Postby Kyoto » Sat Nov 06, 2004 11:46 pm
Les thats an amazing time for the mods you've done. These cars rock! :D
Tim // Melbourne, Australia
1986 ST165. 152,000km on chassis
ST205 WRC engine / IC system / rear LSD with 82,000km
Blitz K1-380V
Apexi Power FC
Aussie 3" dump pipe to 3" catback system
TWM short shifter.
Whiteline front strut brace
Kyoto
Postby alltrac27 » Thu Jan 13, 2005 2:29 am
just wondering, do u lift when shift at all? ive been gettin sub-par times and ive been playing with different driving styles.
Marcus
Society of Automotive Engineers
Gainesville, FL
ST185 (For Sale.... contact me)
www.gatormotorsports.com
alltrac27
Postby LechacZ » Tue Jan 18, 2005 11:19 am
I don't think i lifted my foot off the throttle during that run at all...
Les
ST-205
Ontario, Canada
LechacZ
Postby MARLON1211 » Wed Feb 02, 2005 12:43 pm
Question about the rims, is it a good idea to run on a stock rim on the track.
cause i tired to run my AT with my 17s, and am not quite sure if it affect anything.
SO BE IT
MARLON1211
Postby RIalltrac » Wed Feb 02, 2005 2:30 pm
I've read that the rotational mass(something like that) is different, meaning that the majority of the weight of the rim is further away from the hub and in turn takes more power to get moving. Unlike the stock rims where the diameter is smaller and the majority of the weight of the rim is closer to the hub, meaning less force is required to get it moving. Take if for what its worth, others try to counteract that statement saying that with bigger rims you can also go wider and in turn recieve more traction from a wider contact area to the ground. In my opinion unless your running chrome dubs, I wouldnt really worry about it. I doubt your going to see that much of a difference by changing back to your stock rims for a 1/4 run.
Chris - 90 ST185
RIalltrac
Images: 2
Postby alltrac27 » Fri Feb 04, 2005 12:21 am
...rotational inertia (I=m*r^2), so if there is more mass, farther away from the rotation axis, there is a greater amount of inertia
Marcus
Gainesville, FL
alltrac27
Postby smc252 » Mon Apr 04, 2005 12:00 am
I promise I will shatter this, still finishing mine.
1988 All-Trac
(Rotting away, fiending for a tranny.)
1986 Celica GTS
(GT3071R forced 3s-gte + autronic smc)
smc252
Postby smc252 » Mon Apr 04, 2005 12:09 am
alltrac27 wrote:...rotational inertia (I=m*r^2), so if there is more mass, farther away from the rotation axis, there is a greater amount of inertia
Keep in mind that your driving wheels act just like gears. Bigger wheels will yield better mileage but will lose power over smaller wheels. Bigger wheels DO have more rubber and will last longer then smaller wheels. The largest I'd go is 17", smaller is more preferable.
1988 All-Trac
1986 Celica GTS
smc252
Postby CMS-GT4 » Mon Dec 03, 2007 5:13 pm
Bump. Did you do dyno pulls on this clutch before going to the strip?
I have an awd dyno not far from me, and may not have one when I move so I was thinking about dyno tuning my emanage on the st205 stock clutch to have it done and just leave it off until I can do the clutch down the road.
Return to Racing Chat
