NHRA Legal Battery Box Mounting
Postby exST165 » Thu Aug 23, 2007 3:49 am
Does anyone here have experience mounting a battery box? NHRA rules say that the two 3/8" bolts have to go through a frame rail.
I wanted to mount the box in the rear seat area on the passenger side (with LHD, so right side of the car) but there doesn't appear to be enough space on the frame rail between the bracket for the exhaust hanger and the subframe. The only place I can see is in the trunk on the frame rail that runs above the exhaust, but its going to be a tight fit.
What have people here done?
TIA,
Thomas
exST165
Postby fhalperformance » Tue Sep 25, 2007 1:25 pm
I have mine mounted in the trunk over the exhaust. Its not the easiest install but its functional. I actually made a mistake and had to redrill the box to move it because I still have the plastic pieces installed and I wasnt thinking clearly when I drilled the holes. I can get you pictures later if you want/need them.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Postby exST165 » Wed Sep 26, 2007 2:19 am
Thanks but I have found a spot that I think will meet the letter of the regulation and with some welding will be safe.
I'm putting it where the rear seat used to be on the passenger side, one bolt is through the longitudinal frame rail and the other is going through the lateral structure where the floor pan kicks up to the back seat. The lateral structure is boxed in so I say it is a frame rail, but because of height differences I need to weld in some supports.
Thomas
exST165
Postby CMS-GT4 » Mon Dec 03, 2007 9:05 pm
fhalperformance wrote:I have mine mounted in the trunk over the exhaust. Its not the easiest install but its functional. I actually made a mistake and had to redrill the box to move it because I still have the plastic pieces installed and I wasnt thinking clearly when I drilled the holes. I can get you pictures later if you want/need them.
I would like to see pics.
Postby SBCelicaGT » Fri Dec 07, 2007 10:25 pm
(Disregard the stupid location of the grounding cable. Rather than welding a tab to the chassis, I ultimately decided to run a large cable back to the engine)
This passes NASA's safety inspection. I don't believe a sealed box is needed as this is a spill-proof type battery.
Adrian Avgerinos
90 Celica GT-V6
SBCelicaGT
Postby 90TURBO4WD » Mon Dec 10, 2007 10:40 pm
Do you need an exterior kill switch with a trunk mounted battery?
(kill switch on rear bumper etc.)
JEFF
'90 ST185-project car
'91 ST185-parts car then to be rebuilt
'00 Chev 1500-Daily Driver
up in the great white north
90TURBO4WD
Postby 88st165 » Mon Dec 10, 2007 11:35 pm
90TURBO4WD wrote:Do you need an exterior kill switch with a trunk mounted battery?
does anyone have pics of how they mounted or wired theirs.... i was thinking of putting a switch where the trunk lock cyl is located so i can be easily switched back with no added holes in my car...
Black st165 - gone
2011 FA5 - Family Truckster
88st165
Images: 2
Postby exST165 » Tue Dec 11, 2007 12:18 am
Everything that I've read says that NHRA rules demand a cut-off switch if you relocate the battery, but I have yet to talk to a tech inspector in person.
This guy quotes the rules. Note that by the letter of the rules it has to do more than just cut the battery, it also has to disable the alternator to ensure that it stops the motor if the switch is activated.
http://www.varacers.com/index2.php?opti ... df=1&id=43
88st165 wrote:does anyone have pics of how they mounted or wired theirs.... i was thinking of putting a switch where the trunk lock cyl is located so i can be easily switched back with no added holes in my car...
One way is to use a push rod to activate the switch so you can remove the push rod when you aren't at the track:
http://www.gmhightechperformance.com/te ... index.html
http://www.mustang50magazine.com/projec ... index.html
Or mount the switch behind a tail light that you remove at the track:
http://www.dsmtalk.com/forums/showthread.php?t=181965
I have seen other sites, but I can't find them right now. Google is your friend, good luck.
Thomas
exST165
Postby 90TURBO4WD » Tue Dec 11, 2007 3:31 pm
Good call Google is my friend! :doh:
After only moments of searching I found a good writeup. It is on a Ford Lightning truck but the information is pretty general. It actually reminded me of a couple of things I had missed. And there is a good suggestion for switch placement. Behind the license plate!! I never would have thought haha :P
http://www.timskelton.com/lightning/race_prep/weight/battery_relocate.htm
JEFF
90TURBO4WD
Postby turbo4wd » Tue Dec 11, 2007 5:47 pm
exST165 wrote:Everything that I've read says that NHRA rules demand a cut-off switch if you relocate the battery, but I have yet to talk to a tech inspector in person.
Shortly after I had relocated my battery I went back to Fontana for the street drags they have there and tech inspection wouldn't pass my car because it wasn't equipped with a kill switch.
I had plans on mounting a switch behind the license plate but never got around to it.
Dan
Undercover Moderator
turbo4wd
Return to Racing Chat
