Factory 1/4 Mile times
Postby threefortyduster » Tue Dec 11, 2007 7:30 pm
Ok, so hi. I have a question. There is a kid that works with me who seems to be a little on the wrong side of every automotive argument.
He claims that a 92 Celica ALL Trac, with its 200hp and 200 lb-ft of torque, will run a 14.3 second quarter mile stock. This with its weight of 3200 lbs.
This does not add up correctly. I gave him an example of the first car I bracket raced...a 2001 Dodge Intrepid, which had 230 hp and a race weight (fully filled with gas and me in it) of 3730 lbs. Thats about 430 lbs more than his car would be with stock equipment and him in it. With the parasitic loss of an awd system, and the improvements made to the Intrepid, the vehicles put about the same power to the ground. This car ran a whopping 16.30 at sea level.
So please, can someone 1) explain to me how a car that should run a 15.50-15.80 is going to pick up an extra 1.3 seconds (or 130 hp....) or 2) assist me in letting him know that he is wrong for stock numbers.
Mind you, he has never been on a racetrack, I have bracket raced for 3 years against most everything, and am a regular top-10 points finisher.
Thanks in advance.
threefortyduster
Postby evo » Tue Dec 11, 2007 8:10 pm
not without more boost
I think a stock '92 will run a 15.4 on a good day, they boost a little more than the 90-91, I think they generate more like 220hp since they boost around 10psi at WOT in 3rd 4th and 5th (don't remember about 2nd, been a while since i ran a stock exhaust)
Now keep in mind it's 15 years old, so if it's still stock It would have to be in really good shape to get these numbers
1992/ST185
evo
Postby WarTowels » Tue Dec 11, 2007 8:36 pm
Yeah, when it NEW it's rated at what... 15.3, or 15.4 or something.
I'd be happy if I ran a 16.00.
No way it gonna do 14's without some sort of "out of the factory" mods. Whether that be less weight, slicks, ect. Something out of factory spec.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby jlspec » Wed Dec 19, 2007 10:47 pm
It was 15.2 I believe but it does depend on the driver. To add to the question would be what was the stock recorded time for the 1/8 back in 1990-1993?
jlspec
Postby 2of81 » Fri Dec 21, 2007 12:00 pm
I did a 15.58 at 85.69mph with a totally stock 185 with 18's on it.
Justin
1972 Corolla TE27
2of81
Postby WarTowels » Fri Dec 21, 2007 4:45 pm
Where do you get 15.2 from?
Alltrac.net says 15.3, and every other QM listing I've ever seen has been higher.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: Factory 1/4 Mile times
Postby toayoztan » Fri Dec 21, 2007 8:13 pm
threefortyduster wrote:So please, can someone 1) explain to me how a car that should run a 15.50-15.80 is going to pick up an extra 1.3 seconds (or 130 hp....)
It's not. A stock car, assuming it is running stock boost (sometimes they run more or less due to wear and tear), will only net anywhere from 15.4-15.8 and that's with a good launch and driver.
threefortyduster wrote:or 2) assist me in letting him know that he is wrong for stock numbers.
Is the car completely stock? Does it have exhaust and a boost controller?
To help give him an idea what our cars really run and what's required to hit certain numbers, have him check out this link:
http://www.gtfour.ca/race.html
Bryan
toayoztan
Postby eddie_gt4 » Sat Dec 22, 2007 9:11 am
TOYOTA CELICA TURBO 4WD CARLOS SAINZ
Technical Specification
Maximum speed 143 mph
0-60 mph 7.6 secs
0-400 m 15.4 secs
info from press release
'90 Toyota Celica turbo 4WD ST185 - ex
'96 Toyota Celica GT-Four ST205 - now
eddie_gt4
Images: 11
Postby sirscrtm » Mon Dec 24, 2007 5:26 pm
Wow thats quite the discrepency between 3sgte powered cars.
My gen 3 duce runs 13.3 from the factory, I can find video evidence to prove this if anyone needs it.
Stock quartermile times is not wut counts for ppl that arent afraid to put some money under their hoods, its how much untapped potential is left in the stock motor, and thanks to the stock iron block, and 540cc injectors, the 3sgte is vastly overengineered for making a lot more power than it came with from the factory.
One Al Power on mr2oc made 540whp on stock bottom end, but with a worked head.
One guy on mr2oc even ran an 11.4 using his stock 440cc injectors and a turbo kit/methanol injection kit, stock cams stock ecu, stock unopened motor etc.
sirscrtm
Postby etantshi » Mon Dec 24, 2007 7:33 pm
sirscrtm wrote:Wow thats quite the discrepency between 3sgte powered cars.
Well the discrepency comes in the fact that you're comparing to different 3s motors in two different cars. The gen III has many improvements over the gen II in addition you're comparing a mr2 with an all trac. Different weight different drivetrain. I'm sure if I put a gen III into a 70s corolla I'd rip it up at and make 12s easily.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby Hotrodhendrix » Wed Dec 26, 2007 3:13 pm
racing an intrepid huh.. :lol:
Return to Racing Chat
