friend getting a Tc
friend getting a Tc
Postby gpmarzan » Wed Dec 22, 2004 9:42 pm
so my friend is getting a new scion tc within a week or so. i told him i would race him for fun one day to see if old school (st165 jdm engine) can keep up with a new breed (tc). anyone raced one yet? you think my st165 can beat it? this is all in fun.
gpmarzan
Postby SuperWhite92 » Wed Dec 22, 2004 9:56 pm
use the budget lowering kit from kalecoauto.com on his tC, and you'll win for sure
Shaun
SuperWhite92
Postby omgitsroy326 » Thu Dec 23, 2004 12:12 am
are you talkin bout the supercharged TC??
omgitsroy326
Postby gpmarzan » Thu Dec 23, 2004 12:34 am
omgitsroy326 wrote:are you talkin bout the supercharged TC??
no. just the regular n/a
gpmarzan
Postby omgitsroy326 » Thu Dec 23, 2004 1:17 am
is that even worth your time?
it had 165 torque??? correct how much does it weigh?
omgitsroy326
Postby omgitsroy326 » Thu Dec 23, 2004 1:20 am
Model Scion tC
General Information
Price [$US] from $15,950 (Get the latest price here)
Layout front-engine / front-wheel-drive
Drag Coefficient [cd] 0.32
Curb Weight [lb (kg)] 2905 (1317)
Weight Distribution [%f / r] 58 / 42
Trunk Space [cu ft.] 12.8
Overall Length [in. (mm)] 174.0 (4420)
Overall Width [in. (mm)] 69.1 (1755)
Overall Height [in. (mm)] 55.7 (1415)
Wheelbase [in. (mm)] 106.3 (2700)
Track Front [in. (mm)] 59.3 (1506)
Track Rear [in. (mm)] 59.3 (1506)
Steering Rack & Pinion; power-assisted
Turning Radius [ft. (m)] 18.1 (5.6)
Tires front 215/45 ZR17
Tires rear 215/45 ZR17
Engine
Type Inline-4; aluminum block and head
Valvetrain DOHC 4-valve/cyl.; VVT-i
Displacement [cc] 2362
Bore & Stroke [mm] 88.5 x 96.0
Compression Ratio 9.6:1
Redline [rpm] 6200
Max. Power [Bhp at rpm] 160 at 5700
Max. Torque [lb-ft (Nm) at rpm] 163 (221) at 4000
Bhp/Liter 67.7
Accommodation
Seating Capacity 5
Front Head Room [in. (mm)] 37.6 (955)
Front Leg Room [in. (mm)] 41.6 (1057)
Rear Head Room [in. (mm)] 36.6 (930)
Rear Leg Room [in. (mm)] 33.6 (853)
Interior Noise
Idle in neutral [dBA] 39
70 mph coasting [dBA] 71
Gear Ratios
1st 3.54:1
2nd 2.05:1
3rd 1.33:1
4th 0.97:1
5th 0.78:1
Final drive 4.24:1
Suspension
Front MacPherson struts; coil springs, anti-roll bar
Rear Double-wishbone; coil springs, anti-roll bar
Braking
Front - Brakes 10.8 in. (275 mm) ventilated discs
Rear - Brakes 10.6 in. (270 mm) solid discs
70 - 0 mph [ft (m)] 179 (55.6)
60 - 0 mph [ft (m)] NA
Performance*
0 - 60 mph [secs] 7.4
0 - 100 mph [secs] 20.9
1/4 mile [secs at mph] 15.7 at 88.0
Top Speed [mph] 127
Lateral acceleration [g] 0.81
Fuel Economy [City/Hwy in mpg] 22 / 30
omgitsroy326
Postby gpmarzan » Thu Dec 23, 2004 5:03 am
so its 160hp/163tq/2900 lbs vs my supposibly 225hp/225tq/3200?lbs..i forget the curb weight of my st165
gpmarzan
Postby omgitsroy326 » Thu Dec 23, 2004 8:05 am
weights bout 3200 ish ... woh u have the JDM engine? 225hp /torque
again.... is it worth your time. Let that person spend some money on mods and then race him
omgitsroy326
Postby gpmarzan » Thu Dec 23, 2004 1:23 pm
omgitsroy326 wrote:weights bout 3200 ish ... woh u have the JDM engine? 225hp /torque
Yea i have the jdm 2nd gen 3sgte but its completely stock. I told you its all for fun racing. def worth the time knowing if his new car can get whoop by an 88 celica. muahaha :twisted: ...if its the other way around. ohh well. my excuse is that my car is heavier and its an oldschool. hehehe :D
gpmarzan
Postby maroon_185 » Fri Dec 31, 2004 11:48 pm
You should win no problem.
Chris Fowler
1990 maroon 185 (rc swapped)
1991 red mr2 (3s swap coming soon) Dads
maroon_185
Postby illGT4 » Fri Dec 31, 2004 11:54 pm
power comes from the JDM ECU , not the JDM engine...
you should be able to eat a scion tc for breakfast and lunch.
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby alltracman78 » Sat Jan 01, 2005 6:04 am
gpmarzan wrote:Yea i have the jdm 2nd gen 3sgte but its completely stock. I told you its all for fun racing. def worth the time knowing if his new car can get whoop by an 88 celica.
Yeah, but he's not really racing a 88, you've got like 35 more hp than your supposed to.
Postby Guest » Thu Jan 06, 2005 4:35 am
My g/f got a new tC 5spd. She used to own a 90 AT. Between a 90-93 all-trac stock to stock, it would be a drivers race, seriously.
Guest
Postby illGT4 » Thu Jan 06, 2005 4:54 am
Anonymous wrote:My g/f got a new tC 5spd. She used to own a 90 AT. Between a 90-93 all-trac stock to stock, it would be a drivers race, seriously.
it's always a drivers race. ;) seriously.
illGT4
Postby Gary » Thu Jan 06, 2005 5:46 am
I like the tC. It is roomier, got 2 sunroofs reclining rear seats, and should be a good daily driver. :D
93 ST185
Gary
Return to Racing Chat
