ran my car for the first time
Postby celicanut » Tue Aug 17, 2004 12:23 am
finally got the time off work to go and run my car this past wednesday. i was decently happy with the results. my best run was 14.7 @96 mph. my motor is stock, just turned the boost up to 12 psi. i was happy i beat to 5.0 stangs and a 305 camaro. i'd post the slips i just dont have a scanner.
FS:1991 celica st w/JDM 3sgte conversion
13.9 @ 100 mph
celicanut
Postby Felix » Tue Aug 17, 2004 4:07 am
Nice, w/ it set at 12 psi, you should be hitting at least low 14's/high 13's.
IMO, It seems that you could use more grip (wider/stickier) tires, or you just gotta get your timing right to use the power and not spin the wheels.
Either way, good job :)
1992 Celica ST 5Speed "Midnite Black"
1991 MR-2 GT 5Speed T-Tops "Arrest Me Red"
2005 Scion tC 5Speedd Flint Mica Gray "MY XTC"
-We Miss You- 1990 Celica All-Trac Turbo (G/F's) (Sold)
Felix
Postby Gary » Tue Aug 17, 2004 4:12 am
What is your 60' time?
Are you running stock top mount?
93 ST185
Gary
Postby ChrisD » Tue Aug 17, 2004 2:07 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby BayAreaAT® » Tue Aug 17, 2004 7:03 pm
what RPM did you lauched it at? did you dumped the clutch or you let it slip?
Chris M.
91 ST185 "money sponge"
Ford Ford (Daily Grind)
R1 Yamaha ( Need for speed)
Ford F150
Chrysler 300c Hemi baby!!
BayArea,California
www.Boost2maxx.com
BayAreaAT®
Postby Guest » Wed Aug 18, 2004 2:24 am
here is the info on my slip
R/T: 1.046
60' : 2.495
330: 6.472
1/8 : 9.690
mph: 77.97
1000:12.499
1/4 : 14.778
MPH: 95.59
Mods:
JDM 3sgte swap into 91 st
front mount
MBC set 12 PSI
magnacor plug wires
don't laugh at the r/t guys that was my first time at the track. i didnt spin a lot it bogged alot on my launches bec my fuel curve is so messed up from having a bad knock sensor wire, its dumping in the fuel. before boost was a slug but all my friends that were in the stands said when i hit boost i was gone. which was true everything had me off the line (especially with those r/t's) but still, i caught up quick. my tires were gripping good ive got falken ziex ze 512's. i had slicks but like a dumb ass i sold them. i was slipping the clutch a little but i didnt need to from the bogging. i was launching at 5-5,500 my last two runs so it didnt bog. 3rd run was the best which is what that info is, last i smoked the tires all the way through second. and ive got front mount not top mount.
Guest
Postby SLC Punk » Wed Aug 18, 2004 12:41 pm
Looks like you have plenty of room for improvement. Especially with the reaction time. I usually dump the clutch when it is at the yellow light just before the green. I went to the track for the first time last year and got between a .6-.8 reaction time.
Nice numbers though! 8)
-Travis
1992 ST185
2014 4Runner Trail
2015 Lexus GX460
1978 F250
SLC Punk
Postby BoostJunkee » Sat Sep 18, 2004 2:57 am
That 60' is hurting you.
2.4 is pretty high for AWD. Definitely work on those launches. I can hit a 2.2 on street tires in a FWD Civic, which is still shitty, but I would expect alot more out of yours. Its all in practice tho man, keep it up! 8)
Stupid Honda - 13.6@100mph
BoostJunkee
Postby Gary » Sat Sep 18, 2004 3:35 am
He got JDM swap in FWD celica, not alltrac.
93 ST185
Gary
Postby BoostJunkee » Sat Sep 18, 2004 4:25 am
Gary wrote:He got JDM swap in FWD celica, not alltrac.
oh, in that case, remember that part where I commented? Yeah forget that.
Anyways, get some slicks on the front and kill the launches still!
BoostJunkee
Postby 2of81 » Sat Sep 18, 2004 4:44 am
SLC Punk wrote:Looks like you have plenty of room for improvement. Especially with the reaction time
What will the reaction time do as far as his run? The only time it matters is bracket racing. I can have a 10 second reaction time and a 7 second car and the slip still says 7's.
Justin
1972 Corolla TE27
2of81
Postby BoostJunkee » Sat Sep 18, 2004 4:54 am
2of81 wrote:What will the reaction time do as far as his run? The only time it matters is bracket racing. I can have a 10 second reaction time and a 7 second car and the slip still says 7's.
Agreed. Unless he is racing brackets, screw reaction time. Big points to work on in head the head grudge style are the launch (60 foot time), and from there its just getting good quick shifts and maintaining traction.
BoostJunkee
Postby Shaggz00 » Sun Sep 19, 2004 9:05 pm
just wondering - how come your sig says 13.9 @100MPH?
-Avi-
Shaggz00
Postby mtbgael » Sun Sep 19, 2004 9:13 pm
check two threads down, this is outdated :wink:
Restoring an '88...
mtbgael
Return to Racing Chat
