12sec run SWEDEN
12sec run SWEDEN
Postby Guest » Tue Jul 05, 2005 8:05 am
This time I put on my stock tires/rims(lighter) and advanced the timing, I also put on some fresch injectorsealings.( had a leak )
6500rpm on the starting line and a lot of wheelspin, I finished in 12.793sec and 175km/h.
60´ was 1.77sec :D
st165 88´
fmic,portedhead,portedintake,portedexhaust mainfold,bigger ct26 turbo,15psi,eagle rods,je pistons,TRD clutch, stock ecu and injectors, stock cams
Postby soru » Sun Sep 17, 2006 2:27 pm
wow all that and a stock ecu :shock: . thats a good time think :) :D
Postby Klas » Sun Sep 17, 2006 4:57 pm
Stock injectors and stock ecu and camshafts. My best time is 12.5s. At the moment a haltech is put in together with fiberglas sunroof, fenders, and hood. I´m trying to go 11:s next year and this with a upgraded ct26
1/4 in 12.577s 176km/h so far
If you can turn, you drive to slow!
Now on youtube!
Postby Gary ST165 » Sun Sep 17, 2006 9:18 pm
now that sounds like a "Klas" 165.
what boost are you now running: 1.5-1.3 bar?
come say hi on the UK forums please 8)
Gary ST165
ST165 turbo 4WD
Gary ST165
Return to Racing Chat
