Launching RPM & ?
Does Your GT4 have the power to break traction on all 4's?
Yes
13
50%
No
10
38%
I don't know
3
12%
Total votes : 26
Launching RPM & ?
Postby 91gt4-Newbie » Wed Jul 06, 2005 3:57 am
I ran a search and could not find this info, maybe I did it wrong :doh: . I was wondering what RPM I should launch my new GT4 at. It is a 91. No upgrading except higher flow intake and stage 2 clutch. Also, will the 4 tires break traction at takeoff? I appreciate any input. Thanx
91gt4-Newbie
Postby OlyST185 » Wed Jul 13, 2005 6:32 pm
i seriously think that will need much more power than only exhaust and air filter to loose traction of the 4 wheels.
on the street you need over 350-400awhp im pretty sure.
-Oly (Montreal)
3SGTE'S POWER, 4WD SUPREMACY
[img]http://olyst185.multimania.com/turbo4wd.jpg[/img]
-ST185 1990 Black. RC/CS Conv.
OlyST185
Postby maroon_185 » Wed Jul 13, 2005 6:41 pm
I persoanlly can't, my tires are kinda of wide and my clutch isn't all that freat for launching, however a local 165 that is probably aroudn 200 at the wheels can with a stage 3 clutch.
Chris Fowler
1990 maroon 185 (rc swapped)
1991 red mr2 (3s swap coming soon) Dads
maroon_185
Postby SuperWhite92 » Wed Jul 13, 2005 6:44 pm
You can launch as high as you want, but there's a chance you will spin them just a little bit before moving.
I know my car spins them if I drop the clutch at 6k, but not like a 2wd car would, it just spins for a second, then catches and goes.
I wouldn't worry about it too much.
btw, my car is Less than 200whp with a spec st 2
Shaun
SuperWhite92
Postby Guest » Wed Jul 13, 2005 11:45 pm
I drop it at around 5500 and the front spin a little but it's still enough to get a good jump on most fwd cars and a few rwd. My mods list is pretty short too. I wouldn't worry too much about a little spin cause it's still a hell of a lot better then if you bog it down. That hurts like hell :cry:
Guest
Postby bradc » Wed Jul 13, 2005 11:47 pm
That was me sorry. but no I can't break all 4 yet.
88 st165-"More stickers+more neons=more power right?"
bradc
Postby Zeus » Thu Jul 14, 2005 6:25 pm
You don't need much power to spin all 4 tires rather you just need a good clutch
In reality the best launch will have some wheelspin but there is a fine line between too much and just enough
Blake Brown
Zeus
Postby 92 All-Trac » Sat Jul 16, 2005 3:23 am
I've got an old video of my car leaving four black marks in a parking lot about a year ago. Dynoed only a little over 200 awhp. If someone can host the video maybe they can post it.
Josh
1992 ST185
92 All-Trac
Postby furpo » Wed Jul 27, 2005 10:31 pm
i do dough nuts in mine so it is not too hard to break traction.
roger
furpo
Postby acylon » Thu Jul 28, 2005 6:05 pm
Launch at around 5500rpm
James Unger
'88 ST175 Rally Car (ENZO)
http://www.pregrid.com/acylon/
acylon
Postby slick1851 » Thu Jan 26, 2006 4:23 am
launching at 7,200 with a slight slip. I can light all 4 through all of ist bouncing off the limiter and spin a little in secound....PS I have a Dsm
Only do it once and awhile never all the time, but launching at 5,200 it will still break loose all 4.
EVIII 16G 26psi race gas, HKS 272 Cams built motor blah blah
slick1851
Postby muneo » Fri Jan 27, 2006 5:15 pm
Spin all 4 tires?! Thats easy...
Wait till it rains, run your tires bald and let er rip!
I'm pretty stock but I can chirp all the tires if I rev high enough and slip the clutch just right
Ex-185 Owner
muneo
Postby SuperWhite92 » Fri Jan 27, 2006 7:06 pm
After the exhaust and intercooler, I can seriously spin the tires from anywhere above 5k RPM
edit: 1st gear launching.
Shaun
SuperWhite92
Postby Mafix » Sat Jan 28, 2006 2:35 am
i can roast mine off the rims but mine is 2wd
Postby D_oPsycho » Tue Feb 07, 2006 2:05 am
I can spin mine thru 1st most thru 2nd and chirp 3rd at speed.
Gogo non 4wd 8)
ST184 1991 Celica GT 5S-FE
It might not be as fast as you guys, but it still beats any Civic I've met up with :)
D_oPsycho
Return to Racing Chat
