205 spoiler on 185
205 spoiler on 185
Postby theft and recovery » Wed Mar 12, 2008 10:23 am
i found a nice spoiler off a 96+ gt4 with the riser blocks and would really like to know if they fit on a 185. i think it has been done before. thanks
Why is it hard to convince people that standing in a freezing forest for hours to see a car blast past every couple of minutes is fun? Rally a real test for cars!
theft and recovery
Postby MrDB » Wed Mar 12, 2008 12:56 pm
It has been done but requires some/lot modification.
MrDB
Postby YerRandO » Wed Mar 12, 2008 1:01 pm
I measured the mounting points off my 94 spoiler (same spoiler as the GT4 minus the riser blocks) and it's not even close. It doesn't mount and follow the lines of the hatch like on a 6th gen, it sits more out over the fender.
-James
YerRandO
Postby Tazka » Wed Mar 12, 2008 1:19 pm
Well it's obvious you need to modify it to fit...There's a guy on this forum who's doing that mod on his st185...I don't remember his nick right now though.
Tazka
Postby Hotrodhendrix » Wed Mar 12, 2008 1:28 pm
I will be working on this in the next few months as well. If anyone would like to post more info on it that would be great! I didnt plan on this being a perfect fit on the first try.
I do wish the 5th gens got the slightly raised section on the hatch like the 6th gen. I may just have to make something similar for my 185.
Postby CMS-GT4 » Wed Mar 12, 2008 3:58 pm
I have not seen one on a car w/o the oem 185 spoiler in a long time.
We talk about it in this thread. One member was planning on making custom riser blocks for the 185 so you could get get a standard 20x low spoiler.
I also did a PS of what a shorter one might look like.
http://www.alltrac.net/phpBB2/viewtopic ... &start=255
Postby hacker_720 » Thu Mar 13, 2008 7:52 pm
Hotrodhendrix wrote: I do wish the 5th gens got the slightly raised section on the hatch like the 6th gen. I may just have to make something similar for my 185.
I couldn't agree more, I like the front of the 185 and the back of the 205... someone want to cut 2 cars in half and make my dream car for me?
here's a dumb question.. will the hatch off the 205 fit the 185?
BOTTLE ARE FOR BABIES...REAL MEN GET BLOWN
1990 ST185 2.2Lt
hacker_720
Postby Letze » Thu Mar 13, 2008 10:10 pm
Simple answer... no
long answer... if you have the ass end of a 20x to chop off and the balls to slap it on a 185... then its possible... but not reasonable...
it'd be easier to swap the front end of a 5th gen onto a 6th gen...
Letze
Postby Hotrodhendrix » Fri Mar 14, 2008 2:13 pm
They both have there good and bads but im not a fan of the 185 rear. It needs lots of work to look good. Not to mention the gas tank that leaves you with no exaust choices.
Anyways... I think the 205 WRC spoiler fits the 185's lines really well. Much better than I would have figured.
Didnt I read some where that these spoilers creat so much downforce that it lowers your top speed by a large portion?
Postby CMS-GT4 » Fri Mar 14, 2008 3:29 pm
It may reduce your speeds however I doubt by too much. I am sure 205s could have the same top speeds of the 185. The 205 is supposed to be more aerodynamic as well, so maybe it compensates for it. I mean, what better form of drag can you put on a car than two barn door sized popup headlights.
I know the wing was in place to help keep the cars from taking a nose dive during jumps. Not sure what other benefits it had during racing.
It might be made to look good. I think a 185 will at least need a front lip to balance out the look.
Postby Hotrodhendrix » Fri Mar 14, 2008 3:35 pm
Most definitly a front lip at least. I will probably be going sideskirts and rear bumper as well but its hard to find these that dont kill the lines of our cars.
I will look for that article but I think it said something around 10mph difference!
Postby CMS-GT4 » Fri Mar 14, 2008 3:51 pm
How often are you over 145mph anyway. :D
Postby CMS-GT4 » Fri Mar 14, 2008 4:04 pm
Well, I will be working on a front lip for these cars and there is a savage kit group buy being worked on in another thread.
Postby Gary ST165 » Fri Mar 14, 2008 4:25 pm
Hotrodhendrix wrote:Didnt I read some where that these spoilers creat so much downforce that it lowers your top speed by a large portion?
http://homepage.virgin.net/shalco.com/tte_ST205.htm
The purpose of the rear wing is to correct the inherent balance disadvantage of a transverse-engined car compared with longitudinal-engined models like Fords and Subaru's. The aerofoil has been designed to minimise drag losses while still increasing the downforce and it is effective from 100-120 kph upwards.
"We get better traction and it makes the car more stable. The wing has two positions, up and down, with removable distance pieces. In the Japanese market it will be sold with the wing in me up position and the pieces in place, but to help transport the export cars the pieces will be removed and stowed in me boot ready to fit on arrival. "We are expecting to sell around 2500 examples in Japan alone with the pieces in place. The amount of downforce is influenced by ride height and we still have to carry out wind tunnel tests, but it's expected that there will be 50 kg of downforce at 100 kph with the wing in the up position, and maybe five times more than that with the wing at the low position."
some how that last sentence doesn't make quite sense to me... as i interpret. The spoiler will add 5 x more down force with the spoiler raiser blocks in situe (high position). One thing is for sure it does work, be it on twisty B roads or Vmax attempts on the air strip as tried and tested by many members on the gt4oc.
ST165 turbo 4WD
Gary ST165
Postby Hotrodhendrix » Fri Mar 14, 2008 5:51 pm
CMS-GT4 wrote:How often are you over 145mph anyway. :D
Good point. :twisted:
