making skid plates
making skid plates
Postby l00k0v3rth3r3 » Fri Jun 20, 2008 7:04 pm
Im making skid plates. If anyone is interested let me know, first PM first served, there will be a limited amount, they should be pretty inexpensive.
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
l00k0v3rth3r3
Postby WarTowels » Fri Jun 20, 2008 9:02 pm
Doubt you will get any takers with out A) pictures B) a slightly better and more detailed description.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby Autobot » Fri Jun 20, 2008 10:10 pm
Agreed.
Autobot
Postby l00k0v3rth3r3 » Sat Jun 21, 2008 12:31 am
thanks, ill get them posted up soon!
Gabe
l00k0v3rth3r3
Postby Dracov » Sat Jun 21, 2008 1:09 am
And specify if they're for 185's only or if you'll offer them for 165's as well (hint!)
1988 Toyota Celica Alltrac
Dracov
Postby syko says » Sat Jun 21, 2008 1:39 am
Also, what kind of material will you be using? Will these skid plates have vents to help 'suck' out the heat from the engine?
Aloha,
Evan
syko says
Postby smog7 » Sat Jun 21, 2008 2:10 am
i'm also intersted.... material?? price?? how big??
-omar
rally tarmac 1990 st185
smog7
Postby WideFNopen » Sat Jun 21, 2008 9:08 am
Where are you located?
https://www.facebook.com/peakcityrally
http://cdn.makeagif.com/media/1-12-2015/ZMp5Gn.gif
WideFNopen
Postby l00k0v3rth3r3 » Sun Jun 22, 2008 12:59 pm
im located in MI, as for material i was thinking thin stainless steel, but i put this up for ideas as well as takers. i have the plans drawn up but thats the good thing about pencils it can be changed if you guys have good ideas that i can incorporate into the design that would be great, also if you send me the dimensions for 165 im sure i could bang one out for you.
Gabe
l00k0v3rth3r3
Postby ToySlider » Sun Jun 22, 2008 3:42 pm
i would be interested in skid plates for the st165 also.
1989 Supra Turbo (Goin 1JZ very Soon!!!)
1988 Celica All-trac w/ JDM ST185 engine (Winter Daily/RallyX)
ToySlider
Postby Corey » Sun Jun 22, 2008 4:16 pm
Im interested in 185 skit plates. I like the vent idea.
Corey
Images: 50
Postby nate84 » Sun Jun 22, 2008 10:21 pm
Id be down for a set for my 184!
nate84
Postby Razzo » Mon Jun 23, 2008 4:09 am
l00k0v3rth3r3 wrote:im located in MI, as for material i was thinking thin stainless steel, but i put this up for ideas as well as takers. i have the plans drawn up but thats the good thing about pencils it can be changed if you guys have good ideas that i can incorporate into the design that would be great, also if you send me the dimensions for 165 im sure i could bang one out for you.
you must think about the materials a bit more. stainless steel rusts fast if not painted well. second is weight! i think alluminum would be a better idea, only problem with that is cost...also what thickness of material do you plan on using?
Razzo
Postby aus jd 2703 » Mon Jun 23, 2008 6:36 am
Razzo wrote:. stainless steel rusts fast if not painted well.
are u sure bout this?
all kitchen and medical area's are stainless for several reasons one being iuts corrosion resistant. this comes from the nickel content in stainless
but i do agree stainless is not the best idea it tends to work harden (repetitive flexing will cause cracks faster than a normal steel or aluminium)
aus jd 2703
Postby l00k0v3rth3r3 » Mon Jun 23, 2008 11:00 am
well my original plan was either aluminum or stainless, but the thickness is going to be about 3/64 inches, slightly thicker than 1 mm. This is why I posted before i started, i want your guys input to make it. with one mind, i might not think of things that would be useful to this project. so i appreciate the input keep it coming!
Gabe
l00k0v3rth3r3
