making skid plates
Postby esracing » Mon Jun 08, 2009 1:00 pm
any news?
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby athousandleaves » Mon Jun 15, 2009 2:20 pm
I'd love to hear some measurements for the 185...
I was thinking of making a skidplate out of lexan this summer seeing as Its cheap, light, and fairly durable.
I was also going to add some air vents to help it act more like a diffuser too. Sorta like what the WRC cars ran.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby GT4RC » Tue Jun 16, 2009 1:18 am
Rick89GTS wrote:In case you haven't seen it before, here's a link to Paladek's CUSCO ST165 Skid plate thread (more pics in link):
http://alltrac.net/phpBB2/viewtopic.php ... highlight=
I've seen this skidplate in person. its beefy, and looks hardcore.
GT4RC
Postby athousandleaves » Tue Jun 16, 2009 2:17 pm
GT4RC wrote:I've seen this skidplate in person. its beefy, and looks hardcore.
I bet it weighed a ton!
1992 White turbo4WD
athousandleaves
Postby LegacyofDan » Tue Jun 16, 2009 2:22 pm
/\ nah i doubt it, it is aluminum
Postby athousandleaves » Tue Jun 16, 2009 2:24 pm
all of my friends keep discouraging me from making a skidplate from aluminum cause they say it'll bend way too easily...
1992 White turbo4WD
athousandleaves
Postby Mafix » Tue Jun 16, 2009 2:32 pm
so make it thick.
Postby athousandleaves » Wed Jun 17, 2009 1:03 am
then it'll add too much weight to the front of the car & undo all the weight loss of AC removal etc.
edit
my friends are whiners.
and isn't aluminum pretty expensive?
1992 White turbo4WD
athousandleaves
Postby l00k0v3rth3r3 » Wed Jun 17, 2009 11:56 am
so I purchased my metal stock and its on its way to my house, i went with the 3/16" (~5mm) thick aluminum 6061. It was like $160-170 for a 2' x 4' piece. So we'll see how that works out. I have all the dimensions worked out, still working on a good mounting system, the one posted above looks pretty cool, and easy to do. Once I get this done, I can post some pics of it on and off the car with weight and everything, and let you all know how much it would cost to fab up a few more of course you could pick the material.
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
1953 Dodge B4B 1/2 Ton Pick up - Currently Lawn Art
l00k0v3rth3r3
Postby BNZ » Sun Aug 09, 2009 8:53 pm
Measurements ? WideFNOpen ? GT4RC ?
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Postby smog7 » Sat Aug 15, 2009 6:33 am
so.. anyone willing to make some skid plates?? vendors?? diy handymen??
-omar
rally tarmac 1990 st185
smog7
Postby athousandleaves » Sat Aug 22, 2009 6:22 pm
I'm more than willing to make skidplates... I just need to find the right source for materials and some time to make em... I have some preliminary designs mocked up already on paper with measurements and bolt locations too. :twisted:
Only problem is that I don't have any more money to sink into another project...
1992 White turbo4WD
athousandleaves
Postby BNZ » Tue Aug 25, 2009 7:04 pm
Can you share your plans/designs ?
I want to put them in CAD therms and give them a try at the water cutting machine
Street ST185
Rally ST165
BNZ
Images: 31
Postby makenzie71 » Tue Aug 25, 2009 7:49 pm
aus jd 2703 wrote:are u sure bout this?
all kitchen and medical area's are stainless for several reasons one being iuts corrosion resistant. this comes from the nickel content in stainless.
bzzzzzzzz worng. Stainless is used in medical institutions because it is hypoallergenic and has a high heat tolerance which makes it very easy to sterilize. Has nothing to do with it's ability or inability to rust...and, yes, if it's made of metal, it WILL rust...even stainless.
I make stuff. Lots of stuff. Want some stuff?
makenzie71
Postby makenzie71 » Tue Aug 25, 2009 7:56 pm
wow I didn't realize there were quite so many pages and such...
athousandleaves wrote:then it'll add too much weight to the front of the car & undo all the weight loss of AC removal etc.
edit
Aluminum is a LOT lighter than stainless steel...about half the weight per volume. You could make the plate twice as thick as the stainless piece and be in the same ball park. Also, aluminum is not too expensive. You can get a 2X4 ft sheet of diamond plate for a lot less than stainless.
I've made all my skid plates out of 1/4" dimaond plate because it's strong enough, light, readily available, and cheap. If I hit something hard enough to punch through it, I was lightly doing something wrong anyway and need to adjust my technique.
makenzie71
