Rim Offset help needed
Postby avperformance » Sat Aug 14, 2004 7:01 pm
What would be the best offset to use on a 90 185. The stock rims just seem to be in the wheel well to much.
Tim
89 Supra Turbo (My car)
90 ST185 Alltrac (Friends car)
avperformance
Postby Gary » Sun Aug 15, 2004 1:32 am
Tim,
The stock offset is 39 and stock width is 6.5
What is the width of your new rim?
You can figure the new offset using this site:
http://toy4two.home.mindspring.com/offset.html
93 ST185
Gary
Postby RIalltrac » Sun Aug 15, 2004 2:16 am
Most have to install spacers in the rear to achieve that filled out wheel well look. I have 20 mm H&R spacers which require installing longer studs. There is a 25mm bolt on kit as well, depends on your current offset. [/quote]
Chris - 90 ST185
RIalltrac
Images: 2
Postby Darth Boost » Fri Aug 27, 2004 3:25 am
Gary, I just mounted some super stud ice racing tires on my stock wheels, and using the measuring gauge on the tire machine, I saw them to be 7" wide.
Ji
ST185
Ride with me, and you'll see Jesus so often, you'll swear he's my braking marker.
Middlebury, VT
Darth Boost
Postby Gary » Fri Aug 27, 2004 3:49 am
Ji,
My 7.5 inch OZ measured almost 8 inch from inner lip to outer lip.
I have stock wheels sitting in my apartment with me right now and it wrote 15x6-1/2 JJ39 on the wheels. May be the mounting width is 6.5 :shrug:
93 ST185
Gary
