headlight conversion
Re: headlight conversion
Postby Landon » Tue Apr 12, 2011 4:56 am
i'm in man. for sure. i really wanna make this happen.
White 1995 BMW M3
Black '90 st185 Sold :(
Landon
Postby Flying Bajan » Sat Sep 24, 2011 2:25 pm
Finally got around to installing my Raybrig headlamps in my jdm ST185..... Even with the standard bulbs, they are significantly better than the stock headlamps.... Going to add a set of PIAA xtreme white bulbs and see what they're like then :-)
Flying Bajan
Postby Landon » Sat Sep 24, 2011 4:20 pm
uh guys, i'm getting kinda excited about something. that retrofit company that shows the rx7 with a bi xenon conversion, sells a kit that is basically all you would need except for basically installing the lenses in the car. they also say they do small group buys and such, so i emailed them about it and we'll see what they say, but this could be a really good option for better headlights. let me know what you guys think. 315 for a full kit isn't bad at all.
White 1995 BMW M3
Landon
Postby CMS-GT4 » Sat Sep 24, 2011 5:32 pm
So would this be a low rise kit, or is this something else?
Postby Landon » Sun Sep 25, 2011 6:03 am
i think it would be kinda whatever you want.. cause you could make the lens to sit in the pop up however you wanted, so far as it opened up enough to let the projector lens have full clearance..
White 1995 BMW M3
Landon
Postby Hotrodhendrix » Tue Sep 27, 2011 9:04 pm
I had an idea last night for the smaller projecter lenses. The issue I was running into is how to mount them and be able to direct the light correctly. I was tossing old 3kgt parts away last night and ran into a set of 1st gen pop up 3kgt headlights from an old vr4 I had. They use a smaller 4x6 bulb and a very similar unit behind it.
On the 3kgt it has a backing plate behind the surround which holds the lights in the pick. On the celica it just bolts to the whole unit. It looks like I should be able to remove the 3kgt backing plate and weld it on to the celica unit. This giving the stock base to use the 3kgt headlight and leveling holder. As far as the plastic surround goes I will be cutting the inner portion of the 3kgt's out and fiberglassing it inside of the celica's. This gives me the perfect shape and holes already to adjust the headlight level without removing anything.
Mix this will some 4x6 ecode housings/ cheap generic hid kit or nice bulbs
http://store.sharphid.com/product_p/hella164hbec.htm
Cost:
1. e code housings 100
2. hid kit/nice bulbs 40
3. 3000gt headlight pieces FREE (these are VERY cheap)
4. welding FREE (wont take much or maybe able to bolt it down with some planning)
5. fiber glass FREE ( I already have the stuff. If it works out well I will make a mold of it.)
Total = 140 low rise kit
Postby CMS-GT4 » Tue Sep 27, 2011 9:16 pm
Keep us posted. I had considered using dodge stealth pop ups but there was not battery on the one at the junk yard here to get them popped up to remove. If you get this to work, it might be worth a trip back there. I do wish they were as wide as the celica lenses though.
Postby Hotrodhendrix » Tue Sep 27, 2011 9:21 pm
CMS-GT4 wrote:Keep us posted. I had considered using dodge stealth pop ups but there was not battery on the one at the junk yard here to get them popped up to remove. If you get this to work, it might be worth a trip back there. I do wish they were as wide as the celica lenses though.
True. They would look better if wider. The 3kgt and stealth use the same basic units so either one will work.
Postby Hotrodhendrix » Tue Sep 27, 2011 9:47 pm
Ok so now I am a bit confused.. 3000gt 4x6.. Celica 7x6.. They should be the same width just shorter. I will have to put them up against each other. Now that I look at them in the pic they do look really close.
Postby Landon » Wed Sep 28, 2011 2:17 am
if you put hid's in those... what kinda pattern would you get? i feel like without a projector lens it'd kinda be shitty? what do you think?
i should remember this, but what our stock lens? is it H6054?
White 1995 BMW M3
Landon
Postby concealer404 » Wed Sep 28, 2011 1:58 pm
Landon wrote:if you put hid's in those... what kinda pattern would you get? i feel like without a projector lens it'd kinda be shitty? what do you think?
Yep. It'd be shitty. Potentially even illegal depending on your state.
Yep it is!
Cars and stuff.
concealer404
Postby Hotrodhendrix » Wed Sep 28, 2011 5:20 pm
True. Im just going to go with a nice bulb and be done. Some searching on the enet returns mix results with these housings and HIDs...
Postby Landon » Thu Sep 29, 2011 12:48 am
with that fact, i dunno if it would be helpful, but my old cherokee i had a headlight conversion to a delta housing with xenon bulbs. i was extremely happy with the lighting these provided. for like 150 bucks.. might be a good direct aftermarket option.. it seems like it would be a direct fit...
White 1995 BMW M3
Landon
Postby Hotrodhendrix » Thu Sep 29, 2011 4:18 pm
With the lights changed to the much more common 4x6 size then many more options will be available. Plust your car will look sleepy! :D
Postby CMS-GT4 » Thu Sep 29, 2011 5:05 pm
I wonder if there is a running light hid kit strong enough to stand on it's own that could be mounted on the side vents. Then a conversion for the head lights would not be needed at all.
