Will these rims clear my 205 brakes?
Postby Sal » Tue Jan 19, 2010 1:25 am
Hey guys I'm thinking of purchasing some 16'' Speedline PREO-R rims... Bronze/Gold in color for my white 205...
The rim specs are:
16x7 +48 5x100
wrapped on 205/50/16 tires.
Will these fit the car? I have 5mm spacers all around for the car at the moment...
'94 ST205 GT-FOUR WRC
13.3 @ 101MPH
Sal
Re: Will these rims clear my 205 brakes?
Postby CMS-GT4 » Tue Jan 19, 2010 1:52 am
Whats your oem specs? I kind of doubt at that ET they will fit. I have seen some 17x8 ones on a faff, but not some that narrow and high et.
Postby Sal » Tue Jan 19, 2010 3:49 am
OEM: 16 x 7.5 On 215 50 16 tires
Offset is +45
13.3 @ 101MPH
Sal
Postby CMS-GT4 » Tue Jan 19, 2010 12:19 pm
Honestly, I would hold out for something else. No sense in downgrading for looks. It would not hurt to take off your wheel and take some measurements so that you could get and idea of what might fit. Look at some of the BBK websites. They have templates to download to see if your wheel fits their kit. I would advise making something similar.
Postby Meurz » Tue Jan 19, 2010 8:42 pm
Gary ST165 has such a set on his RC, he might be able to send you some dimensions to find out?
Turbocelica.nl
Meurz
Postby Sal » Wed Jan 20, 2010 3:31 pm
Yea that would be great. I'll give him a PM.
I want these rims bad! I don't really like the look of 17's on a 205.
Here's a 205 with these rims on. I tried checking the GT40C wheels thread but had no luck in finding someone with these wheels and comments on them!
13.3 @ 101MPH
Sal
Postby Gary ST165 » Wed Jan 20, 2010 6:55 pm
my instinct is that ET48 wont clear the ST205 calipers.
but...
http://www.gt4oc.net/forums/viewtopic.p ... ne#p757495
Rob_A wrote:Speedline SL 1102
16x7
et35
obviously ET35 don't require spacers ;)
You might be in luck...tomorrow i am going to see my good friend datajon, and i have to take my speedlines off as they have no tyre tread left. I will ask if i can test fit one of them to his ST205. Can't promise anything...
I've got to use my ST205 3 spokes on my RC :( as they have new tyres. I originally put these aside for my ST165 :roll:
ST165 turbo 4WD
Gary ST165
Postby Sal » Wed Jan 20, 2010 8:38 pm
Ok cheers Gary please let me know!
It would save me an hour 1/2 drive over to the shop that has these rims :wink:
13.3 @ 101MPH
Sal
Postby Meurz » Wed Jan 20, 2010 9:28 pm
Gary ST165 wrote:I originally put these aside for my ST165 :roll:
You also read HyperRev, sir? 8)
Turbocelica.nl
Meurz
Postby Sal » Fri Jan 22, 2010 2:32 pm
Any luck fitting the rims Gary?
13.3 @ 101MPH
Sal
Postby Gary ST165 » Fri Jan 22, 2010 3:33 pm
no joy Sal. my mate isn't at the workshop today or yesterday :(
i won't see him again until probably next wednesday.
ST165 turbo 4WD
Gary ST165
Postby Sal » Fri Jan 22, 2010 6:21 pm
Ok cheers mate let me know if you ever have the chance to do it :)
I might end up at the dealer next week!
13.3 @ 101MPH
Sal
Postby ChrisD » Fri Jan 22, 2010 6:55 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby etantshi » Mon Apr 05, 2010 12:52 pm
ChrisD wrote:It's really got more to do with the shape of the spokes than the offset itself. Spokes are the same distance from the caliper no matter what the offset on a given rim style.
Those ones look like they have a good chance of fitting because the spokes push 'out' so to speak.
Exactly. The ET won't tell you much on if the wheel will fit or not over a st205 caliper.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby darthripley » Fri Apr 16, 2010 9:30 pm
i've got the same rims in silver, but 16x7 +38mm et & they clear the front 205 calipers - however i did have to add a 3mm spacer to clear the lower ball joint since the car is a ST185.
i think the rims would clear simply due to the spoke design .. but it might be close & don't quote me on it :twisted:
this is the front 205 hub/knuckle test fitted onto our rim - it cleared, but was close - the only pic i have is from the backside:
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
