Dynamat as Hoodliner
Postby redGT4 » Fri Jan 29, 2010 12:39 am
My hoodliner must be the original one, so after twenty years its held up fairly well, but needs retirement. I was considering Dynamat products as the replacement, with the oil / water resist Dynaliner over the silver Dynamat.
Anyone know it holds up as hoodliner? How long it lasts, problems with it etc.
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
redGT4
Re: Dynamat as Hoodliner
Postby Sifu » Fri Jan 29, 2010 1:43 pm
I've seen forum members use dynamat (or their less expensive counter part that completely escapes me). I've also heard the debates of the older fire pad and what it is suppose to do vs. pulling it out and replacing it with dynamat.
So yeah you can.
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby TRDcelica90 » Sat Jan 30, 2010 7:47 am
why do u want one though? i run without it, doesnt ruin the paint at all!! save ur money!!!
1990 Toyota Celica GT-FOUR RC Now with the power of a Garrett GT30!!
1987 Toyota Celica GT-Four ST165 Rally car in the making..
TRDcelica90
Postby redGT4 » Sat Jan 30, 2010 8:25 am
TRDcelica90 wrote:why do u want one though? i run without it, doesnt ruin the paint at all!! save ur money!!!
Then i'd have to cut and polish the inside of the bonnet. Then regularly clean it. :cry:
redGT4
Postby cmonteiro1 » Thu Feb 04, 2010 10:52 pm
Someone also made something out of some of that silver heat reflecting material you can buy at a hardware store. It actually looked pretty sharp. Not sure how well it functioned though. Anyone have link to that picture? I don't have a hood liner at all.
1991 ST185
Mods:
Aussie DP, 3in Exhaust, Wideband A/F, BayArea FMIC, HKS SSQ Blow Off Valve, Forge Waste Gate Actuator, AEM ECU, SARD 800 , Walbro Pump, ATS Fuel Rail Mod, ATS Fuel Pres. Reg. Mod., 60 trim upgraded ct26.
cmonteiro1
Postby aus jd 2703 » Fri Feb 05, 2010 6:59 am
imo depending on colour combo but polished aluminum between the reinforcement mmm sexc
on another note i was wanting to make my cabin of my gt4 quieter has any one had experiences with adding sound deading like dynamat? what are the key areas to lower cabin noise?
aus jd 2703
Postby Landon » Fri Feb 05, 2010 8:12 am
why would you have to cut and polish it? i'm confused. lol. i pulled mine, painted it flat black, and dust it down with every car wash. its pretty simple. seems like the engine would almost run cooler too. paints stayed fine too. yours should have good paint under it? look at ripleys car. they took it out and it looks good underneath.
White 1995 BMW M3
Black '90 st185 Sold :(
Landon
Postby redGT4 » Sat Feb 06, 2010 5:37 am
Landon wrote:why would you have to cut and polish it? i'm confused. lol. i pulled mine, painted it flat black, and dust it down with every car wash. its pretty simple. seems like the engine would almost run cooler too. paints stayed fine too. yours should have good paint under it? look at ripleys car. they took it out and it looks good underneath.
The paint is okay condition from the areas i can peek at, but would need to be cut back, then polished, glazed and waxed for me to be satisfied. I'm planning to enter her in a show in march so i cant clean the bay then leave the bonnet looking shit, thats just plain f'ing wrong in my book.
aus jd 2703 wrote:imo depending on colour combo but polished aluminum between the reinforcement mmm sexc
I've added it to a mates doors, made a huge difference with the bass rattles. For less cabin noise then i would go thick carpet underlay, in the boot also, with some dynamat in the doors. There is varying thickness materials in the dynamat range, their website gives a good idea of whats what. In the end though its tires and exhaust that have the biggest impact. I'll be adding some when i do my interior makeover...someday...
So no ones seen it last underbonnet over a few years? :shrug: I'll give it a go anyway.
redGT4
Postby GT4RC » Sat Feb 06, 2010 7:40 am
after sound deadening the trunk in my gts, there were a few days of 40+ degrees celcius heat that made it go soft, and the tar seeped out the edges and made a bit of a mess. if you're going for show quality finish, avoid any instance where you can visibly see the edge of the dynamat.
and for unbranded dynamat www.b-quiet.com
good luck, I'm also interested in seeing how it holds up.
GT4RC
Postby ulis_m86 » Sat Feb 06, 2010 10:34 am
hope darthripley doesnt mind this is from darthripleys page imo the sexiest underhood i seen so far. :notworthy: her and her husband do some sweet detailed and tedious work check out her project
http://alltrac.net/phpBB2/viewtopic.php?f=44&t=19242&start=360
ulis_m86
Postby redGT4 » Sun Feb 07, 2010 5:42 am
Awesome. Food for thought. Cheers ulis_m86
redGT4
Postby WarTowels » Mon Feb 08, 2010 4:42 am
They used heat reflective 'stuff' not dynomat though.
Perhaps consider Thermo Tec Adhesive Backed Heat Barrier: http://cgi.ebay.com/ebaymotors/Adhesive-Backed-Heat-Barrier-12-x-24-NEW_W0QQcmdZViewItemQQhashZitem5ad6e3a853QQitemZ390152300627QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby MWP » Fri Feb 12, 2010 12:13 am
The black stuff in dynamat (and others) is like tar... wouldnt it melt??
Postby WarTowels » Fri Feb 12, 2010 2:19 am
It certainty could melt, and produce a gross mess or worse even a fire hazard.
I personally wouldn't put dynamat as the hood liner, I'd use some that is made to with stand the heat not something made with withstand sound.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby darthripley » Sat Feb 13, 2010 9:40 pm
thanks for the props guys - got me blushing here :oops:
we used the thermo-tec heat reflective self-adhesive material, just like the link Towels posted.
i wouldn't use anything not rated for some kind of heat b/c it will melt off in time & make a gigantic mess all over the place.
the thermotec has held up well so far & will save the paint on your hood from cracking which it will start to do if you don't have some sort of heat shielding on the underside.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
