Dynamat as Hoodliner
Re: Dynamat as Hoodliner
Postby redGT4 » Sun Feb 14, 2010 5:34 am
Thermotec or similar. Something that will stand 200+ c degrees. I'll keep on looking and researching.
Thanks for the replies guys/gals. Give yourselves a pat on the back. :D
54 trim hiflowed ct26; Custom top mount;2 1/2" exhaust; Turbosmart boost controller(not fitted); Autometer CF series; Everything else stock; The Haunter of the Hills.
Postby chaos_cascade » Thu Feb 18, 2010 5:36 am
There are tons posts of dynamat type products melting/failing in the texas heat. I think unless your trying to collect on your show car insurance you might want to reconsider mounting that above your turbo and intercooler.
Postby Einst3in » Tue Sep 21, 2010 2:53 am
on a separate note, i know this is old but the factory liner is designed to melt and help extinguish any under hood fires as well as keep most heat off the hood.
-90 Alltrac
-02 Taco
Postby toayoztan » Wed Oct 20, 2010 7:36 am
Einst3in wrote:on a separate note, i know this is old but the factory liner is designed to melt and help extinguish any under hood fires as well as keep most heat off the hood.
Bingo. Not sure though if the actual "blanket/liner" melts or the clips melt allowing the liner/blanket to drop over the fire (althoug the liner is already in close proximity lol).
I believe also the material of the underhood liner acted as a thermal barrier/insulator to help prevent heat transfer to the hood = damage to your paint.
If you want a proper hood liner, order the material online and cut what you need and make it fit.
If you're going for show, I'd just repaint/clean up the paint on the underside of the hood, and make sure you have your heatshield on your manifold (at a mininum).
I plan to just have all my "hot parts" titanium coated or some sort. It's amazing how much ambient heat is decreased from this.
Honestly, I never thought of underhood liners originally to be much protection for paint with proper heat shields, etc, but more a fire blanket/sound reduction. One thing to remember, a lot of the older cars (such as ours) have aged (general wear and tear) enduring multiple weather conditions, and the paint chemistry was a bit different back then perhaps. I'm not bringing this up to state that protecting the paint is a moot point, though (just adding rationalization to a side). But I will agree that these liners may confer some protection for the paint from the heat, being secondary to why liners are now used.
"EDIT": Just found this...thought it was pretty interesting.
http://www.mvfri.org/Contracts/Final%20 ... lation.pdf
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
