Leaky weatherstripping?
Postby smog7 » Sun Dec 19, 2010 6:49 am
Does anyone else notice water dripping from their door speaker holes when it rains? I don't have any speakers in at the moment and I can see water dripping down the plastic and onto my carpet.... Is my window weather stripping screwed? Or is this the result of screwed weather seals within the door?
-omar
rally tarmac 1990 st185
smog7
Re: Leaky weatherstripping?
Postby st185rc » Wed Dec 29, 2010 9:52 pm
i think there needs to be a sticky for water leaks. mystery leaks happen in our cars far too often. right now i have a leak in the left side of the hatch even after replacing the weather stripping in the trunk. after it rains and after i move the car, you can see water streaming down the side into the rear seats.
damn old cars
st185rc
Postby 92 All-Trac » Thu May 26, 2011 4:09 pm
smog7 wrote:Does anyone else notice water dripping from their door speaker holes when it rains? I don't have any speakers in at the moment and I can see water dripping down the plastic and onto my carpet.... Is my window weather stripping screwed? Or is this the result of screwed weather seals within the door?
I have the exact same problem with my car. Primarily on the driver side. I'm suspecting the stripping as well, but thought I'd look around on here before I replace them. Have you fixed your problem yet?
Maybe this thread can get moved to Maintenance/Repair?
Josh
1992 ST185
92 All-Trac
Postby DudeMan » Fri May 27, 2011 3:34 pm
Doesn't really have to do with weatherstripping but there's a drain tube in each quarter panel that deposits water from the hatch, directly into the rocker panel..
If anyone wants to save themselves some rust work, I'd suggest routing this tube so it doesn't simply pool in the rocker/quarter panels.
Just thought I'd mention that.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby 92 All-Trac » Fri May 27, 2011 3:53 pm
Thanks for the tip...
To access them you have to remove the interior quarter trim? Where do you redirect the tube to? Seems that since Toyota designed it this way, there must be another logical repair (not that your idea is bad)...maybe something in the rocker itself?
Josh
1992 ST185
92 All-Trac
Postby toayoztan » Sat May 28, 2011 5:27 am
92 All-Trac wrote:Thanks for the tip...
Yeah, I honestly don't know where the tube is supposed to drain to in the rear quarter panel. I look underneath and dont' really say any hole for this. I plan to route it somehow...unless i figure out what the hell it connects to and if it wont' simply just dump water in the rocker.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby 92 All-Trac » Sat May 28, 2011 5:45 am
I'm still not sold that this is where my water leak problem is, but I will eventually look into that rocker issue.
My problem is that I'm getting water dripping out of the door, comes from the between the door panel and the actual door. I think the outer window trim on the door is allowing water to run in between it and the window glass. I can't figure out how else water would get in? There's no other sign of water besides it dripping from the bottom of the door then onto the plastic rocker trim.
Josh
1992 ST185
92 All-Trac
Postby DudeMan » Sat May 28, 2011 3:04 pm
Sorry, I kinda went off topic with the drain hose.
To access it you have to remove the rear seats, the panels and the System 10 speakers if you have them.
It will look like this.
Anyways, back on topic.
If I were you I'd just spray the door down with a garden hose, check inside and repeat until you've found the leak.
Maybe remove the interior door panel if you have to.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby Awesome-Trac » Sat May 28, 2011 5:13 pm
are we talking about the weatherstripping between the door mirrors where speakers are usually mounted on?
•Daniel
Awesome-Trac
Postby 92 All-Trac » Sat May 28, 2011 5:51 pm
DudeMan wrote:Sorry, I kinda went off topic with the drain hose.
Damn, that's pretty bad man. Here on the west coast rust isn't too much of an issue unless you really neglect a car, but I still want to address that hose.
DudeMan wrote:If I were you I'd just spray the door down with a garden hose, check inside and repeat until you've found the leak
This is what I'll likely do once it stops raining here!
Josh
1992 ST185
92 All-Trac
Postby 92 All-Trac » Sat May 28, 2011 5:52 pm
awesome-trac wrote:are we talking about the weatherstripping between the door mirrors where speakers are usually mounted on?
Yeah, I'm talking about the piece that runs along the top of the door on the outside.
Josh
1992 ST185
92 All-Trac
Postby Awesome-Trac » Sat May 28, 2011 7:30 pm
lol...then i have the same problem then.
•Daniel
Awesome-Trac
