Fender Replacement
Fender Replacement
Postby timco » Sun Feb 13, 2011 7:45 pm
My passenger side fender is dented up/scratched/rusted. Looking to replace both the driver side and passenger side. Anyone know where to look? Checked a couple of places with no luck. Either stock replacement or maybe carbon fiber(if found). Let me know.
thanks
kris
88 All Trac
2nd gen 3sgteRC
[Image
timco
Re: Fender Replacement
Postby timco » Mon Feb 14, 2011 5:57 pm
Anyone?
88 All Trac
2nd gen 3sgteRC
[Image
timco
Postby celi_wabbit » Mon Feb 14, 2011 6:59 pm
timco wrote:Anyone?
look into your local salvage yard for GTS fenders, it's your best shot.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
Postby timco » Mon Feb 14, 2011 10:39 pm
Will the gts fenders fit w/o being flared? Not that being flared is a huge issue I guess. Was thinking they were a bit different.
Thanks for the response,
Kris
88 All Trac
2nd gen 3sgteRC
[Image
timco
Postby timco » Mon Feb 14, 2011 10:56 pm
88 All Trac
2nd gen 3sgteRC
[Image
timco
Postby celi_wabbit » Tue Feb 15, 2011 1:11 am
timco wrote:Will the gts fenders fit w/o being flared? Not that being flared is a huge issue I guess. Was thinking they were a bit different.
Kris
If you have the 5th gen celica, GTS fenders are flared and bolts right up.
1993 MR2 N/A - Sold
1995 Tacoma - Sold
2010 Mercedes-Benz
celi_wabbit
Postby timco » Tue Feb 15, 2011 2:18 am
ah I have the 4th gen ><
Things are just not available anywhere. Cant find the part number for them(im blind i guess) to ask toyota if they have any.
88 All Trac
2nd gen 3sgteRC
[Image
timco
Postby 187flatliner » Tue Feb 15, 2011 4:23 am
no the supra fender will not work....
ANY FENDER OFF OF THE 4TH GENS...NO MATTER THE ....ST/GT/GTS/ALLTRAC.....ARE THE SAME. THE ONLY DIFFERENCE IS THE ALLTRAC WHICH CAME WITH THE LOWER FRONT MOLDINGS ATTACHED. IF YOU HAVE THE LOWER MOLDINGS THEN ANY FENDER WILL WORK. YOU JUST HAVE TO MOUNT THE LOWER MOLDINGS.
GOT PROBLEMS WITH MY FWD
187flatliner
Postby cmonteiro1 » Fri Jul 08, 2011 10:54 pm
Not sure if you found a solution yet, but this is what Id do if I needed to swap fenders
http://www.gt4.com.pl/polyurethane/inde ... Itemid=103
1991 ST185
Mods:
Aussie DP, 3in Exhaust, Wideband A/F, BayArea FMIC, HKS SSQ Blow Off Valve, Forge Waste Gate Actuator, AEM ECU, SARD 800 , Walbro Pump, ATS Fuel Rail Mod, ATS Fuel Pres. Reg. Mod., 60 trim upgraded ct26.
cmonteiro1
Postby DudeMan » Sat Jul 09, 2011 4:39 pm
I can only imagine how much it would cost to ship two fenders from Poland to the US.. Probably enough to defeat the purpose.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
Postby Toyota_Todd » Fri Jul 15, 2011 3:24 pm
Toyota part number is #53801-2B080 (RH Fender)and is discontinued (at least in the USA).
Last known retail price for the above fender was $258.11.
They list a fender for the std coupe and liftback. Still available. #53801-20840 Retail $302.20 6 shown to exist in the USA.
And they also list a fender for the conv. Discontinued....
Without modifying a standard Celica fender, you are looking for a 1988 or 1989 Alltrac only fender. There seems to always be somebody parting an ST165 out on the boards. Just remember that the cladding that Toyota added on those fenders can hide a lot of sins...namely rust. You may be better off to have the seller show you the fender without the trim on it or modify a standard fender.
Good luck.
Todd Longenbaugh aka Toyota_Todd
1992 Celica All-Trac Turbo "Seeing Red"
1992 Celica GT-Four RC Conv. "Fatal Alltraction"
2001 Avalon XLS "the wifes family truckster"
1971 Pontiac Ventura II "The token domentic"
Toyota_Todd
