speedline wheels
speedline wheels
Postby jonnyboygt4 » Tue Feb 15, 2011 9:09 pm
what do you guys think if these wheels? thinking about sporting them on the celica...
these are supposed to be right from japan...can anyone confirm this?
http://toronto.kijiji.ca/c-cars-vehicle ... Z259136949
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Re: streetline wheels
Postby CMS-GT4 » Tue Feb 15, 2011 9:13 pm
I think the offset is way to high.
Postby alltracst185 » Tue Feb 15, 2011 9:20 pm
Agreed! Subie offsets :wink: you would need at least 15mm spacers
alltracst185
Postby jonnyboygt4 » Tue Feb 15, 2011 9:24 pm
alltracst185 wrote:Agreed! Subie offsets :wink: you would need at least 15mm spacers
ive got 33mm on the rears...i shouldnt need anything foor the front would I? gonna be running k sport pro coilovers aswell...
i just paid for them.. im expecting them some time next week...
91 JDM ST185
jonnyboygt4
Postby alltracst185 » Tue Feb 15, 2011 9:26 pm
At least a 10mm spacer in the front unless you don't like the flush look :shrug:
alltracst185
Postby jonnyboygt4 » Tue Feb 15, 2011 9:29 pm
i'll have to test fit the fronts...i run my ROH wheels slightly tucked in the front just barely...when i bought those rims they came off a cavalier....im pretty sure they were +48 also...
but does anyone have any insight about these being JDM wheels?
91 JDM ST185
jonnyboygt4
Postby alltracst185 » Tue Feb 15, 2011 10:06 pm
I beleive that speedlines are in fact a true JDM wheel. Very popular with the Subie crowd :)
alltracst185
Postby jonnyboygt4 » Tue Feb 15, 2011 11:15 pm
with say a 10mm spacer...do you think ill need longer studs?
91 JDM ST185
jonnyboygt4
Postby alltracst185 » Tue Feb 15, 2011 11:31 pm
Most likely my wheels are 17x8 +38 offset and i run a 1.25" spacer in the rear. The fronts are almost perfectly flush.
alltracst185
Postby jonnyboygt4 » Tue Feb 15, 2011 11:33 pm
just ordered some 8mm spacer off ebay...ill try these out...hopefully i wont need longer studs ...i think i should be fine...hopefully...
91 JDM ST185
jonnyboygt4
Postby klue » Wed Feb 16, 2011 12:02 am
thats a terrible idea, anything over 3mm and your risking having your wheel come off
Postby jonnyboygt4 » Wed Feb 16, 2011 12:13 am
klue wrote:thats a terrible idea, anything over 3mm and your risking having your wheel come off
bahh then looks like ill have to hit up "my parts guy" lol
91 JDM ST185
jonnyboygt4
Postby alltracst185 » Wed Feb 16, 2011 1:07 am
I have run spacers front and back on my trac ever since i bought it with no problems at all, so that is just hear say! :twisted:
alltracst185
Postby klue » Wed Feb 16, 2011 5:32 am
alltracst185 wrote:I have run spacers front and back on my trac ever since i bought it with no problems at all, so that is just hear say! :twisted:
"Hear say"?!?!?!. If you have a 10mm(for reference) long portion that fits into the stud then the load is shared across 10mm of metal.
10-8 = 2mm do you think 2mm of thread contact is sufficient to support a 3400lbs vehicle? I personally don't.... Good luck with that
Postby jonnyboygt4 » Wed Feb 16, 2011 7:40 am
i hear what your saying.....there wont be enough thread for the rim to properly thread...i was looking at hubcentric 15mm spacers but it looks like you either have to cut the stock log nuts to shorten them so they dont stick past the spacer..or have grroves in your rims...which i dont have....so i went witha spacer that just slides over the lugnuts.....if i need longer studs...no big deal...just a little more work to do for me this spring...
91 JDM ST185
jonnyboygt4
