Thinking about buying these rims...need info.
Postby 92 All-Trac » Thu Jun 09, 2011 1:08 am
So this guy has a set of these Enkei's for sale and they are in great shape. The tires are 225/45ZR17 with about 70% tread. All I know about the wheels is that they are 17" and are universal 5-lugs. I've tried searching online for more info about the wheels, offsets that they come in, weight, etc, but all I can find is that they are "Enkei Racing Wheels."
Does anyone know anything about these, and if they are a good fit on 5th gens?
Josh
1992 ST185
92 All-Trac
Re: Thinking about buying these rims...need info.
Postby alltracst185 » Thu Jun 09, 2011 1:19 am
Just go and try them on :shrug:
alltracst185
Postby 92 All-Trac » Thu Jun 09, 2011 1:47 am
They're like 3 hours away :/
Josh
1992 ST185
92 All-Trac
Postby alltracst185 » Thu Jun 09, 2011 1:57 am
Call and ask him what it says on the back of the rims, all the info on them should be there.
alltracst185
Postby YerRandO » Thu Jun 09, 2011 2:06 am
enkei rsf-2 17x7 the only offset I could find was 40, no clue if it was offered in any other width or offset combo
-James
YerRandO
Postby magnum » Thu Jun 09, 2011 2:14 am
Enkei RSF2 came in these sizes.
17x7 +40mm
18x7 +40mm
Silver w/polished lip
magnum
Postby 92 All-Trac » Thu Jun 09, 2011 2:48 am
^ Thank you! That's what I was looking for. I emailed him earlier about the offset, but he didn't seem to understand lol. Still debating on how they will look...
Josh
1992 ST185
92 All-Trac
Postby lumbercis » Thu Jun 09, 2011 2:48 am
The most important bit of info is whether these are 5x100 bolt pattern. If not they won't fit at all. If he doesn't know what you mean ask him the last car these were mounted on.
Personally, I wouldn't be caught dead putting 40 offset wheels (or 7" wide wheels for that matter) on an alltrac, but to each their own.
J.
Caldina powered...
lumbercis
Postby magnum » Thu Jun 09, 2011 3:08 am
they came in 5x100 and 5x114.3. On an All-trac they will look sunk in like the factory wheels.
magnum
Postby 92 All-Trac » Thu Jun 09, 2011 3:30 am
Yeah, I'm wanting to get rid of that nasty inset look so I'm likely going to pass on these.
Josh
1992 ST185
92 All-Trac
Postby jonnyboygt4 » Thu Jun 09, 2011 9:50 am
magnum wrote:they came in 5x100 and 5x114.3. On an All-trac they will look sunk in like the factory wheels.
nothing a set of wheel spacers cant take care of...ive got +48 offset on my car flushed out with spacers...
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Postby 92 All-Trac » Thu Jun 09, 2011 9:17 pm
Very true, but I'd rather go with a wheel with a better fitting offset to avoid an 1"+ thick spacer. I know its not a big deal, but just my preference :)
Josh
1992 ST185
92 All-Trac
