Ideas for 165 hood vents
Postby UtahSleeper » Wed Feb 15, 2012 7:53 pm
So, when I get a replacement hood for my 165 I am planning on mounting some vents towards the back. Something I can bolt in. My current plan is to look at universals on ebay, find something that seems to match the shape of the car, add bolts and use them.
My question is, what vents have you seen that you think would look good on the 165?
UtahSleeper
Re: Ideas for 165 hood vents
Postby monkey8oi » Wed Feb 15, 2012 8:07 pm
dont know how big you were thinking regarding the vent.. i personally like this one.. just gotta figure out how to mount it.. http://www.ebay.com/itm/Universal-Hood- ... 41588ed726
monkey8oi
Postby UtahSleeper » Wed Feb 15, 2012 8:17 pm
I like the one, but I am aiming a little smaller. Closer to the 185 in size and location.
UtahSleeper
Postby UtahSleeper » Wed Feb 15, 2012 8:32 pm
One idea was somethign like:
http://www.ebay.com/itm/Universal-Black-Air-Flow-Fender-Mesh-Side-Hood-Vent-R3-/150756379287?hash=item2319c7ca97&item=150756379287&pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
My plan would be to cut the hood for each one, but leave enough metal around each hole to recess the vent and make mounting locations. If that make sense.
UtahSleeper
Postby 88gt4DE » Wed Feb 15, 2012 8:58 pm
If the 185 ones are still available what about those ?
Postby UtahSleeper » Wed Feb 15, 2012 9:06 pm
Hmmm.............might have to look into that. I also thought they had more rounding and countour since the hood on the 185 has more curve. Just another option to explore.
UtahSleeper
Postby 88gt4DE » Wed Feb 15, 2012 9:13 pm
UtahSleeper wrote:Hmmm.............might have to look into that. I also thought they had more rounding and countour since the hood on the 185 has more curve. Just another option to explore.
Good point , I havent seen a 185 one up close for awile and not alot. Now that I think about it those are more curved than ours .... hmmmm got me thinking too. I want to do something too for heat. not a fan of the hood crop ....
Postby UtahSleeper » Wed Feb 15, 2012 9:17 pm
Yea, I know the heat on these things suck. Thats probably one of a few reasons why the harness on my trac is toast. I figure some simple, but good looking, vents should do the trick. No reason for a scoop for me since it's W2A and I will eventually just being going front mount.
UtahSleeper
Postby concealer404 » Wed Feb 15, 2012 9:29 pm
Cars and stuff.
concealer404
Postby jaydog82 » Thu Feb 16, 2012 2:56 am
I kinda like that
jaydog82
Postby 88gt4DE » Thu Feb 16, 2012 11:47 am
Me too actually ... clean ...
Postby UtahSleeper » Thu Feb 16, 2012 3:45 pm
Any other ideas?
I like the aluminum vents, but I would never use them cause of the mounting method. Plus, I wouldn't trust my body work skills to make it blend with the hood.
UtahSleeper
Postby concealer404 » Thu Feb 16, 2012 3:52 pm
UtahSleeper wrote:Any other ideas?
..... what mounting method are you looking for?
Cars and stuff.
concealer404
Postby UtahSleeper » Thu Feb 16, 2012 5:04 pm
Something like the 185 (The normal vents or CS, both just "fit" the style of the car its on). Slightly thicker material that holds screw/bolts in it, or can be made to hold them so they can be tightened down under the hood. Trying to find a vent that fits the body styling angles of the 165 and can be made to look like it belongs there from the factory.
I will figure something out. The aluminum you posted might get used on my rolla cause they are a mild vent. I just posted this thread since I assume I am not the only one who has had this idea :) So wanted to see what other ideas people had.
Some vents I have been considering are:
Then there is always the option of doing as legacy of dan has done, just not sure how good that will be on a car that will spend all it's time outside, not under cover.
I also would like something like below, but some concerns as listed above.
UtahSleeper
Postby Anoo21 » Thu Feb 16, 2012 5:22 pm
i was jus gonna do some bolt on vents but just cutting a whole that fits the body lines are just as good.
We have pretty much the same style hood and front as a ae86 heres some pictures
Anoo21
