carbon fiber radiator shroud any interest
Re: carbon fiber radiator shroud any interest
Postby Corey » Fri Mar 30, 2012 2:37 pm
Alcantara on the shelf would be pretty slick.
If that ever happens, I'm in.
Corey
Images: 50
Postby temperacerguy » Sat Mar 31, 2012 12:45 am
concealer404 wrote:
Plug as in CF Sunroof plug? WANT.
No... "a plug" is the shape used to make the mold. But you did hit on a project probably 5-6 out.... more on that MUCH later.
temperacerguy
Postby temperacerguy » Sat Mar 31, 2012 1:14 am
Corey Darling wrote:Alcantara on the shelf would be pretty slick.
OK, well I have about 7-8 rolls of different colors of alcantara already. It's an amazing fabric, and I am a huge fan of it. I mean come on, when Lamborghini uses it as it's "upgrade" over leather, it can't be bad, can it?
The only problem I have with Alcantara is that there are so many faux "alcantara-like" fabrics out there that wannabe posers call "alcantara" that it's ruined the name. It's like all those people who wrap their hoods, or interior in Di-noc and say they "carbon fiber wrapped" their items... Grrr, it's just lame...
Anyways, Carbon fiber is about $50 a yard shipped. Alcantara is $100 per yard and requires a bit more work... I can use the same mold to make a carbon fiber version as well as an Alcantara covered fiberglass version, so when I do this, I'll offer two versions:
Carbon fiber (with a flattened automotive clear) for those who go after appearance above all.
Alcantara covered fiberglass (probably for $50 more) in either a dark grey (to match the factory shadow grey), or dark blue to match the factory blue (as close as possible)
Here's a pic I took just to prove that I can get one unit out of a yard of fabric... This is a medium Grey
Here's a sample grey and blue that I would be using for these.... (9052, 9055)
temperacerguy
Postby temperacerguy » Sat Mar 31, 2012 1:16 am
hmm... 9041 might be better for the blue....
temperacerguy
Postby Corey » Sat Mar 31, 2012 3:57 am
Alcantara on fibreglass would be fine in my opinion. But I'm wondering, what would be the weight difference compared to the standard shelf if completely wrapped in the fabric?
Would it be possible to do the carbon shelf, but with just the top being covered in alcantara? That way when the bootlid is opened you can still see the bling of a cf shelf, but have the benefits of the glare reduction with the alcantara on top while keeping the weight down.
If it ends up weighing more than the standard shelf then there isn't much point. :shrug:
Edit: just as a reference point, the stock shelf weighs 2.98 kg
Cheers
Corey
Images: 50
Postby temperacerguy » Sat Mar 31, 2012 12:15 pm
There is really going to be little reduction in weight with this item. The standard item (I'm an american here, so excuse my imperial measurements) is 6.6 lbs
a carbon fiber version will be around 3.5lbs
a alcantara covered fiberglass will be around 4.5lbs
This is less about weight savings, and more about appearance, and replacement of an item that is no longer available, as few have survived the years.
It could be made with an alcantara top and a carbon fiber bottom, but the bottom side would not be a totally "finished" glossy appearance as the bottom is the vacuum bag side, and the costs would definitely go up by at least another $35. HOWEVER, it's a good idea, and I will be doing this for my unit, damn the costs. LOL
Now, I havn't done a pure cost analysis of this... But off the top of my head, pricing would probably be $250 for a carbon fiber shelf, $300 for an alcantara shelf with a $35 up charge for a carbon fiber bottom.
temperacerguy
Postby l0ch0w » Sat Mar 31, 2012 9:38 pm
Hey put me on the list too :)
Andrew
1991 Red Alltrac
l0ch0w
Postby CMS-GT4 » Tue Apr 03, 2012 12:42 am
I am not sure your interested but plenty of members would be interested in a cover for low rise headlights.
Postby l0ch0w » Wed Apr 04, 2012 12:52 am
^this x 1 million...
Andrew
1991 Red Alltrac
l0ch0w
Postby RafaCalde » Fri Apr 13, 2012 3:47 pm
Any updates on this. Just curious. Would love to have a shroud like this.
Rafa
RafaCalde
Postby celigts » Fri Apr 13, 2012 4:43 pm
I'm out. Just for laid off and don't need this but would have loved it.
3SGTE project motor very slow
celigts
Postby celi_wabbit » Fri Apr 13, 2012 11:25 pm
I'm in as far as I can tell...
1993 MR2 N/A - Sold
1995 Tacoma - Sold
1991 Celica Alltrac - Sold
1994 Celica GT - Project
2010 Mercedes-Benz
celi_wabbit
