Headlights/spotties... what have you done?
Re: Headlights/spotties... what have you done?
Postby psipwrd » Tue Dec 09, 2014 4:07 pm
Looks Sweet! I want projectors but I think i'll go with the trucklite for simplicity.
psipwrd
Postby Eurus » Wed Dec 10, 2014 8:03 am
For a 165 I recently upgraded my Hella H4 Conversion housing with Osram Cool blue bulbs. Dont have a good night shot, especially since they're angled weird. Definitely a huge difference though, and contrary to what the coating on the bulb would make you believe, they aren't blue.
I have a set PIAA Xtreme white fogs I need to install too. They seem to be the only fogs that should fit the stock location of a 165.
Eurus
Postby gryMiCaST184rc » Sat Feb 28, 2015 5:58 am
My PIAAs
Bay Area
ST184RC
gryMiCaST184rc
Postby FC Zach » Thu Apr 07, 2016 5:21 am
Edit: Updated dead links of my Truck-Lite install on a previous page.
I also resolved this little issue (like ZeroDrift mentioned) I had with the install some time ago but forgot to update this thread. .
ZeroDrift wrote:Must say they work quite well- however with the low amp draw these have, the MR2 no longer has an operational hi-beam indicator lamp.
FC Zach wrote:Wonder how that can be corrected? ?
801Alltrac wrote:OMG :D that looks great, great work FC Zach
I knew they would look great, I wonder if there is a resistor would work
FC Zach wrote:I'm wondering if I could measure and record the ohms with the factory and new light installed then just buy a resistor sized close to the difference of the two? Does that make any sense? (It does in my head lol) Then do I just simply install it inline on the high beam wire?
801Alltrac wrote:That's what I think would work
MWP wrote:It wont.
You'll need to rewire the light in the dash.
What I did to fix this little issue: Instead of using a resistor I simply attached a small 194 bulb to each light.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby FC Zach » Thu Apr 07, 2016 5:39 am
For fog lights, I found some small LED accessory lights off Amazon for cheap. I made my own mounts to get them where I wanted them.
FC Zach
Images: 9
Postby fussellbug » Thu Apr 07, 2016 9:05 am
Did you put the 194 bulb in series or parallel? Where did you physically put the bulb?
fussellbug
Images: 36
Postby FC Zach » Thu Apr 07, 2016 9:28 am
Parallel with the low beam lead, tucked the bulb (mounted in a socket with two leads) behind the Truck-Lite on the headlight harness.
FC Zach
Images: 9
Postby CMS-GT4 » Thu Apr 07, 2016 3:30 pm
Are those led fogs legal for road? I wonder if they might fit the rc center grill like oem.
Postby FC Zach » Thu Apr 07, 2016 9:04 pm
Probably, as long as you don't have a front mount.
FC Zach
Images: 9
