Round Headlights
Round Headlights
Postby bluntninja » Mon Oct 08, 2012 11:40 pm
bluntninja
Re: Round Headlights
Postby underscore » Mon Oct 08, 2012 11:48 pm
I've seen something similar, looks kinda dumb IMO.
Postby 4rsnduction » Tue Oct 09, 2012 4:13 am
There are tutorials on this site somewhere detailing how to make your own.
Its not expensive and requires no real technical knowledge
4rsnduction
Postby fussellbug » Tue Oct 09, 2012 9:07 am
Te best looking set I've seen was made by http://neeltec.co.uk/ as a one-off custom job for one of their clients. You can see from the pictures on their website that it's not very difficult to put together. NeelTec used the 90mm Hella modular high and low beam lights for their setup.
fussellbug
Images: 36
Postby underscore » Tue Oct 09, 2012 2:21 pm
what the hell did they do to that poor car!
Postby fussellbug » Wed Oct 10, 2012 1:06 pm
Based on the NeelTec pictures above and info from Fiero and MR2 forums the following should be all the materials needed to complete the quad headlight conversion.
Light assembly:
(2) HL68137 -- H9 halogen projector low beam (DOT compliant)
(2) HL68136 -- H9 halogen high beam (DOT compliant)
Sheet metal for bracket fabrication
Plastic or fiberglass for fabrication of lens surround
This drawing is of Hella part #97300 mounting plate for 90mm modular lights. This provides dimension for making an adapter plate like NeelTec did.
Wiring Adapters (make 2) http://www.fiero.nl/forum/Forum2/HTML/095436.html
16 AWG (or higher) Wire
(4) Hella HL87193 H9 female connectors (or equivalent)
(2) Hella CPH4CM H4 male connectors (or equivalent)
This is a rough wiring diagram of the adapters.
All that's left is modifying the Headlight lifting cam and arm to raise the headlight to the proper height. This will require fabricating a new, shorter cam to bolt to the motor and shortening the arm so that the motor rotation causes less vertical movement than the original factory setup. The sleepy eye mod may be a viable alternative to this if you can get accurate repeatable open height.
***EDIT***
this supra owner gives a good explanation of how to adjust the headlight opening height
http://www.supramania.com/forums/showthread.php?18540-The-best-HID-low-profile-(sleepy)-headlight-mod-for-under-500
fussellbug
Images: 36
