Aftermarket wheels on STOCK suspension
Postby lumbercis » Sat Dec 08, 2012 3:50 am
Interested to see some pics of non-stock wheels on stock suspension. Be sure and mention whether your car is a 90-91 or 92-93 as I've been trying to figure out if there were ride height changes to the springs between the years.
From the wheel size thread to give you an idea:
17x9 +30 not sure of year
Caldina powered...
lumbercis
Re: Aftermarket wheels on STOCK suspension
Postby Awesome-Trac » Sat Dec 08, 2012 7:00 am
I'm running a 17x8 +48 offset on my 1990 celica on stock suspension
•Daniel
Awesome-Trac
Postby lumbercis » Sat Dec 08, 2012 4:48 pm
lumbercis wrote:Interested to see some PICS of non-stock wheels on stock suspension.
Caldina powered...
lumbercis
Postby kn0wledge185 » Sun Dec 09, 2012 2:00 am
1993 on stock suspension
17x9 et35 245/40/17
kn0wledge185
Postby lumbercis » Mon Dec 14, 2015 11:39 pm
Looks good man! (zombie BUMP :P )
Caldina powered...
lumbercis
Postby underscore » Mon Dec 14, 2015 11:43 pm
17x7 et??? on stock 91 GTFour RC suspension
Postby msanders2 » Mon Dec 28, 2015 5:30 am
90 Alltrac with Enkei Rpf-1 17x9 +35. Stock suspension.
msanders2
Postby Rallly » Sat Feb 13, 2016 10:53 am
Awesome-Trac wrote:I'm running a 17x8 +48 offset on my 1990 celica on stock suspension
Can you post pics or send to 17054921335 plz:)
Rallly
Postby alltracman78 » Sun May 15, 2016 2:41 am
RC cars have ~ 1" shorter springs than the regular 185s, FYI.
Postby underscore » Sun May 15, 2016 6:13 am
Really? Either mine were swapped out or it's not really an inch, my car seemed taller than normal on the stock ones.
Postby alltracman78 » Sun May 15, 2016 9:43 am
From what I recollect on my old 92. I still have the springs but they're sitting in my garage along with all my other spare stuff.
Postby clayton351 » Sun May 15, 2016 2:11 pm
Do you have some pics of this? Are you running any spacers? Looking at a set with those specs as well
clayton351
Postby Awesome-Trac » Mon May 23, 2016 4:57 am
I don't at the moment cause I'm running 18x8 now with the rear on 25mm 5x100 to 5x100 adapters with hub centric rings. On the 17x8 setup I had 30mm spacer adapters which made the wheels stick out alittle but was flushed to the fenders BUT caused a lot of rubbing so I suggest going with the 25mm
•Daniel
Awesome-Trac
Users browsing this forum: Google Adsense [Bot], Yahoo [Bot] and 1 guest
