wheel figment st165
wheel figment st165
Postby ST165Sleeper » Wed Aug 14, 2013 1:16 am
anyone know if a 16x8 25mm offset will fit under my st165?
ST165Sleeper
Re: wheel figment st165
Postby killemalltrac » Sun Aug 25, 2013 2:17 am
I'll know soon with a 15x8 +25. I just ordered them a few minutes ago. Which wheels are you looking at?
#80sMurderCar
killemalltrac
Images: 10
Postby ST165Sleeper » Tue Oct 29, 2013 1:57 am
I was looking at these here:
http://www.tirerack.com/wheels/WheelClo ... sort=Brand
As a side note if anyone wanted to photoshop these on to a 165 that would be cool to see.
ST165Sleeper
Postby Jeebus » Fri Nov 29, 2013 11:41 pm
You can view the rims on your car via the TireRack website. To the right of the screen, it shows you the price, and the price per tire, right beneath the price per tire & tire availability, there's a button "view on vehicle". As long as you have your car chosen, it'll pop up a new window with your selected car, which you can choose the body colour as well.
Jeebus
1994 Toyota Celica
Postby Eurus » Mon Dec 02, 2013 6:23 am
Jeebus wrote:You can view the rims on your car via the TireRack website. To the right of the screen, it shows you the price, and the price per tire, right beneath the price per tire & tire availability, there's a button "view on vehicle". As long as you have your car chosen, it'll pop up a new window with your selected car, which you can choose the body colour as well.
This doesnt work for 165s, it will show a 185.
Check this site I have been using for a while http://www.rimsntires.com/specs.jsp its a good way to compare.
The site I posted will give you the difference that you need to measure on your car to see if they will fit.
However, you need to know what size tires youll be running to decide if it will fit.
Eurus
Postby ZeroDrift » Fri Mar 07, 2014 3:24 am
Bump- Any updates?
Postby killemalltrac » Tue Apr 01, 2014 2:31 pm
well the 15x8 +25 fits with a 205/50/15. They rub occasionally in the rear and the front tire got torn up on the inside of the fender. Will roll all four courners and should be fine. Might even end up with 10mm spacers in the rear to bring them out to the same plane as the front.
#80sMurderCar
killemalltrac
Images: 10
Postby Awesome-Trac » Tue Apr 01, 2014 4:59 pm
I've done
-15x7 1990 gts flowerpower wheels "no spacer"
-15x7 2000 GT wheels "no spacers"
-16x7 2002 GTS wheels "no spacers
-17x8 Work emotion cr Kai "30mm 5x100 to 114 adapters"
-18x8 SSR SP1 "25mm 5x100 to 5x100 adapters"
•Daniel
Awesome-Trac
Postby killemalltrac » Mon Apr 07, 2014 2:38 pm
Awesome-Trac wrote:I've done
This would be much more useful if you had offsets listed too ;)
#80sMurderCar
killemalltrac
Images: 10
Postby ST165Sleeper » Thu May 15, 2014 3:11 am
Will a 15x7 5x100 et 42 fit the 165?
ST165Sleeper
Postby killemalltrac » Thu May 15, 2014 2:47 pm
ST165Sleeper wrote:Will a 15x7 5x100 et 42 fit the 165?
it should. And I think it will be sunken in a little bit. Isn't that almost the factory size?
#80sMurderCar
killemalltrac
Images: 10
Postby ZeroDrift » Thu May 15, 2014 5:55 pm
I think it may fit, but a wide tire may rub against the spring perch/strut.
Postby ST165Sleeper » Fri May 16, 2014 5:28 am
Thanks guys. Yeah I know tire sizing is going to be a pain but I plan to go as wide as possible with the tires. I just have to find a tire shop here that will work with me and experiment with test fitting different sizes. I'm gonna be running BFG g-force KDW unless someone has a better idea for a solid summer tire with good enough venting for went conditions and standing water. I do live in Oregon after all and it rain 9 months out of the year.
ST165Sleeper
Postby ZeroDrift » Fri May 16, 2014 12:15 pm
Look into Federal 595-RSR. Heard great things about that tire.
Postby ALLensTRAC » Fri May 16, 2014 2:50 pm
Michelin Super sports are an awesome combo of dry/wet traction! The RSR gets real "interesting" in the rain lol.
Allen
ALLensTRAC
