ST185 trailer hitch?
Postby fhalperformance » Sun Aug 18, 2013 11:06 pm
Anyone ever put a trailer hitch on their trac? I was thinking of turning my new trac into a tow vehicle for my mr2 when I go to the track. It would certainly turn heads & if the mr2 breaks down I can take the trac out for some fun.
'93 trac - V6TT project.
'91 trac - 564awhp.
'91 mr2 - parting out.
'04 ducati 999
'04 tacoma TRD - for sale
fhalperformance
Re: ST185 trailer hitch?
Postby Toyota_Todd » Sun Aug 18, 2013 11:44 pm
Uh, I tow with my ST185 Celicas and there is no way in hell that your going to trailer your Mr2 behind your Celica. Just my 5x8 utlity trailer with a garden tractor or dirt bikes is quite a workout for our cars. I do call it my pickup truck but pulling another car on a trailer is a no go. I do not believe the bolt on hitches from Reece would be up to the weight task of hauling a car either. The other issue is finding a hitch. They are discontinued and very hard to find. Good luck with your MR2 at the track though!
Todd Longenbaugh aka Toyota_Todd
1992 Celica All-Trac Turbo "Seeing Red"
1992 Celica GT-Four RC Conv. "Fatal Alltraction"
2001 Avalon XLS "the wifes family truckster"
1971 Pontiac Ventura II "The token domentic"
Toyota_Todd
Postby fhalperformance » Mon Aug 19, 2013 12:10 am
I have been toying with the idea for a while. There are ppl pulling 1000kg caravan that has trailer brakes brakes with a 2000 Celica gt, figured an Alltrac could do similar with a proper hitch. Saw a Porsche hooked to the back of a car with a tow bar so the owner can get it to the Trac but I'd rather have it off the ground. I don't got a motor in the Trac yet so it's just an intellectual excercise at this point.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby FC Zach » Mon Aug 19, 2013 12:14 am
Yeah, the most I pull with my car is a motorcycle and that is probably pushing the limit.
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby FC Zach » Mon Aug 19, 2013 12:24 am
Granted, it is a rotary with no torque LOL so towing anything is almost pushing the limit.
FC Zach
Images: 9
Postby fhalperformance » Mon Aug 19, 2013 12:49 am
Im putting a 5vzfe v6 in my 93 trac so I will have plenty of torque for towing. Uprated clutch, st205 tranny, maybe throw in some stiffer springs & tires that can take some extra weight on them safely. Maybe a tow dolly like a uhaul one with a dolly under the rear wheels like used by tow trucks to haul 4wd vehicles.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby fhalperformance » Mon Aug 19, 2013 1:10 am
example A:
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby phattyduck » Mon Aug 19, 2013 4:36 pm
A (bolt-on) hitch receiver for the Alltrac would attach to the bumper. 200lb tongue weight and 2000lb trailer weight. No way you are going to tow a car on a trailer safely. Most car trailers are close to the limit without a car on it!
I happily tow with my WRX (and will with my Camry Alltrac once I get a wiring harness on it), but I wouldn't go over the trailer weight limit for the vehicle.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby fhalperformance » Mon Aug 19, 2013 9:31 pm
I understand there's no way a bumper hitch can handle it. I'm thinking a custom hitch that ties into the crossmember/suspension pickups/maybe even install a proper roll cage I can tie into. I should look how the wrx hitch attaches for some inspiration draw up a cad drawing of an Alltrac hitch.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby phattyduck » Tue Aug 20, 2013 4:15 pm
fhalperformance wrote:I should look how the wrx hitch attaches for some inspiration draw up a cad drawing of an Alltrac hitch.
The WRX hitch bolts on to the bottom using the same bolts that hold the bumper and original tow loops (you can find install instructions on etraler.com and similar sites). Most are then 1 1/4" thick wall square tube for the cross bar under the bumper. The Celica has the bumper bolts inside (from the hatch/trunk area), so you will have more trouble using that part of the frame rail for strength.
There should be some welded nuts on the bumper beam already as a starting point for your fabrication. I'd still caution you to avoid towing too much weight with such a light vehicle... :wink:
phattyduck
Postby underscore » Tue Aug 20, 2013 5:30 pm
You also have to consider your tires, brakes, suspension, and chassis strength here. Not to mention if something does break under braking, the rear end of your Alltrac will be destroyed.
Postby fhalperformance » Tue Aug 20, 2013 10:17 pm
The weight of the tow vehicle isnt that important although it seems like a better idea for it to be heavier then the payload being towed. F650s are rated to tow weights as much as three times their curb weight depending on the frame selection. Not that an F650 really can be compared with an alltrac lol. Then again Im not expecting to tow a trailer at 80mph, it would be no more then 65mph probably to keep the load on the car down.
Brakes, tires, suspension are all fixable issues. Im not really concerned with worrying about those items at this point since there are options. I do have to do some research on clutches used by trucks with manual transmissions to see what kind of setup I would need to have to keep the clutch from slipping with the amount of weight that can be on it potentially.
underscore: what do you mean if something breaks the rear end will be destroyed?
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby sinerasis » Tue Aug 20, 2013 10:26 pm
With all the modifications you're talking about, wouldn't it just be easier, cheaper, and better to just get an old beater pickup truck?
Jeff
1989 ST165 Black
sinerasis
Postby fhalperformance » Tue Aug 20, 2013 11:00 pm
It would be easier but probably not cheaper. Ive had my eye on a inexpensive truck worth spending money on but for the money the trac would probably be cheaper to do, far more practical & doesn't require a monthly payment.
I have a problem not turning every vehicle I own into a project lol. Plus, it would be alot more fun to take the trac out if I break the mr2 at the track & be alot more interesting as a tow vehicle then a truck. Other then the performance sacrifice of higher load rated tires (maybe?) the rest are all mods most people do to the car (with a twist) minus the hitch of course.
'91 trac - 564awhp.
'04 ducati 999
fhalperformance
Postby underscore » Tue Aug 20, 2013 11:05 pm
fhalperformance wrote:Brakes, tires, suspension are all fixable issues.
Frame strength isn't tho. Any how usable is rear suspension strong enough for towing a car going to be the rest of the time?
fhalperformance wrote:underscore: what do you mean if something breaks the rear end will be destroyed?
If either the hitch, or what the hitch is mounted to (or anything else really) fails under braking, you've got an awful lot of weight getting plowed right into the back of your Alltrac. In a more conventional setup this isn't much of a risk, but when venturing into unknown territory it is.
