Front bumper help.
Front bumper help.
Postby toybota » Wed Feb 26, 2014 9:24 pm
I have been trying to remove the bumper off my ST185, Turbo 4WD. I have undone all the bolts underneath, be the headlights and the plastic screws by the crash bar. I can't find any others and I've read at this point you use brute force. Before I go reefing on the thing and inevitably break things :doh: AM I MISSING A BOLT?
El Coño My 1990 ST185 Canada delivered Turbo 4WD. Bought for $1000. You could say it needs some work.
'00 Focus Wagon - Soon to be gone.
'90 St185 'El Coño'
'93 St184 Parts car
'85 MA61 Supra Daily Driver
toybota
Re: Front bumper help.
Postby FC Zach » Wed Feb 26, 2014 10:55 pm
Are there any in the fender well?
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby r-town » Thu Feb 27, 2014 5:04 am
Usually the fender retainers are the ones that require some force to remove.The plastic clips hold the bumper really well.
r-town
Postby toybota » Thu Feb 27, 2014 10:11 am
I have all the bolts for the fenders taken off, and I can see a bolt holding the fenders on that can't be reached because of the bumper. Where are the clips you said that need some force to take off?
'90 St185 'El Coño'
'93 St184 Parts car
toybota
Postby r-town » Thu Feb 27, 2014 2:46 pm
Maybe you already unclip them. This is from a GT-s. I have marked the bumper support brackets, and they are riveted with a retainer. Each support has two small handles that snap into the fender plastic clip. This helps the bumper have a flush look with the fender. The first time I removed my bumper I didn't know it had those, and I thought I was missing a bolt somewhere.
r-town
Postby fussellbug » Thu Feb 27, 2014 8:27 pm
in the picture r-town posted, part# 52675A is the plastic clip. There are two on each side, one directly above the other at the front edge of each fender. On the inside of the bumper there are a couple of metal rods on each side that snap into these plastic clips. Based on the age of these plastic clips, it is likely that one or more of the plastic clips will break when you pull the bumper off. To order them use part # 52675-20010. The list price is $2.44 each.
fussellbug
Images: 36
Postby toybota » Thu Feb 27, 2014 8:36 pm
Thank you guys so much was not expecting that detail of a response :D . Toyotas over engineering is such a good thing to have but sometimes, it is a real pain in the ass. I'll go try that.
'90 St185 'El Coño'
'93 St184 Parts car
toybota
Postby toybota » Thu Feb 27, 2014 9:57 pm
So I got everything undone. But now I can't get my hand in to undo the turn signal bulbs so I can take the bumper away from the car. Gotta wait for someone with small hands to show up. :doh:
'90 St185 'El Coño'
'93 St184 Parts car
toybota
Postby underscore » Fri Feb 28, 2014 2:27 am
You can't undo them? Just unscrew them, pull them out a bit and remove the bulb.
Postby toybota » Fri Feb 28, 2014 10:07 am
I know how to take bulbs out, I just couldn't get my hand in, the gap was too small. After fiddling with the bumper though I got my hand in.
'90 St185 'El Coño'
'93 St184 Parts car
toybota
