How well will these wheels fit my car?
Postby fruci101 » Wed Apr 23, 2014 1:41 am
I just purchased the 17" wheels that can be found on the new Scion and Subaru BRZ. Wheels are 17x7 +48mm offset with 215/45R/17 tires. I am just wondering how well these will fit in my ST185, especially with the offset. Thanks.
fruci101
Re: How well will these wheels fit my car?
Postby Awesome-Trac » Wed Apr 23, 2014 3:07 am
Yup
•Daniel
Awesome-Trac
Postby underscore » Wed Apr 23, 2014 5:03 am
That's a pretty high offset so you might have to run a spacer.
Postby phattyduck » Wed Apr 23, 2014 4:38 pm
Center bore is also wrong, so you will likely get some vibrations at speed.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby fruci101 » Wed Apr 23, 2014 5:34 pm
phattyduck wrote:Center bore is also wrong, so you will likely get some vibrations at speed.
Is there a way to fix that problem?
fruci101
Postby underscore » Wed Apr 23, 2014 6:44 pm
hub centric rings or lug centric lugnuts IIRC.
Postby fruci101 » Wed Apr 23, 2014 6:50 pm
Thanks guys! Appreciate the help
fruci101
Postby phattyduck » Wed Apr 23, 2014 9:47 pm
Not really for such a close difference in hub bore. Toyota 5x100 is 54.1mm and Subaru 5x100 is 56.1mm. You'd need a 1mm thick ring and they don't sell it as far as I've found (i'd love to be able to put stock Subaru wheels on my Alltrac...)
phattyduck
Postby fruci101 » Thu Apr 24, 2014 12:51 am
phattyduck wrote:
Hey guys,
So I guess they make custom fit ones at http://www.motorsport-tech.com/hub_rings.html.
On the other hand, couldn't I properly bolt the wheels on (star pattern - evenly tightening lugs up) then be fine? The lugs are tapered to center of the wheel on the studs, so as long as they're tightened up properly wouldn't I be fine without hub rings?
fruci101
Postby underscore » Thu Apr 24, 2014 2:02 am
phattyduck wrote:
Wrap a layer of 1mm tin tape?
Postby loudstealthGT-Four » Thu Apr 24, 2014 9:40 am
fruci101 wrote:
Hey guys,
Yes it is completely fine to run without hubcentric rings, aslong as the wheels are tightened correctly with tapered nuts/lugs.
I have been running 70mm centrebore wheels on my car for the last 20000kms/12000miles, with some very hard gravel/sealed and grass racing, along with daily driving. And have never had any issues
With that offset, the wheel will sit very close to the rear strut (shouldn't cause any issues). Ran that exact size wheel on my car.
loudstealthGT-Four
Postby phattyduck » Thu Apr 24, 2014 4:12 pm
loudstealthGT-Four wrote:Yes it is completely fine to run without hubcentric rings, aslong as the wheels are tightened correctly with tapered nuts/lugs.
Its not a safety issue, but there is a very good chance that there will still be vibration even if the lug nuts are tightened correctly. Maybe only at 70mph+ or whatever, but it will be there.
phattyduck
Postby loudstealthGT-Four » Thu Apr 24, 2014 11:42 pm
phattyduck wrote:Its not a safety issue, but there is a very good chance that there will still be vibration even if the lug nuts are tightened correctly. Maybe only at 70mph+ or whatever, but it will be there.
Not arguing with ya :D
But I beg to differ, a vibration on a wheel will be causing stress on the wheel studs (so is definitely a safety issue).
I have never had any issuses with vibrations, even while doing 200+kph/120+mph
loudstealthGT-Four
