Enkei rpf1
Enkei rpf1
Postby Mr Alltrac » Mon Jun 09, 2014 5:47 pm
How well would 17x9 +45 fit on a st185?
Mr Alltrac
Re: Enkei rpf1
Postby CSAlltrac » Mon Jun 09, 2014 7:00 pm
That offset is far to high. Wheels would probably be in contact with struts. If they weren't (95% sure they would be) they will be sucked in. Check out the wheel sizing and offset thread for 185s. Tons of relevant info.
Re: Enkei rpf1
Postby Mr Alltrac » Mon Jun 09, 2014 7:05 pm
I figured cause I think the offset is for a brz/frs.
What size are you running on your car, +22 with a 15 mm spacer in the rear?
Or do I have it backwards? What about 45 +10 mm spacer?
Mr Alltrac
Re: Enkei rpf1
Postby underscore » Mon Jun 09, 2014 8:58 pm
I've got 17x8 +45 all around, I think I needed a 5mm spacer in the rear to just barely clear the coilovers and the fronts hit the frame without spacers. With a 17x9 you'll need an extra half inch of spacer just to bring the inside edge to the same place as my 17x8.
Re: Enkei rpf1
Postby Mr Alltrac » Mon Jun 09, 2014 10:45 pm
Hmm so do you know of a good offset/spacer? I just like the flat face on rpf1 and I know the 8 has just a slight convex.
Mr Alltrac
Re: Enkei rpf1
Postby CSAlltrac » Tue Jun 10, 2014 12:05 am
I'm 17x9 +35 W/ a 25mm spacer in the rear
Re: Enkei rpf1
Postby Mr Alltrac » Tue Jun 10, 2014 1:51 am
Were those a custom made set? I can't find that size anywhere.
Mr Alltrac
Re: Enkei rpf1
Postby CSAlltrac » Tue Jun 10, 2014 2:29 am
They were a custom run yes.
Re: Enkei rpf1
Postby Mr Alltrac » Tue Jun 10, 2014 11:34 am
Damn that sucks (for me), well done sir, they are a great fit!
Mr Alltrac
Re: Enkei rpf1
Postby Mr Alltrac » Tue Jun 10, 2014 7:57 pm
Do you run at all? Did you roll your fenders?
Mr Alltrac
Re: Enkei rpf1
Postby underscore » Tue Jun 10, 2014 9:35 pm
Just get 35mm rear spacers, extended front lugs and a 10mm front spacer and you've got the same thing as CS.
Re: Enkei rpf1
Postby Mr Alltrac » Wed Jun 11, 2014 2:15 am
35 mm spacers on what size of rim and offset?
Mr Alltrac
Re: Enkei rpf1
Postby underscore » Wed Jun 11, 2014 7:58 pm
17x9 et35 + 25mm spacer = 17x9 et45 + 35mm spacer
Re: Enkei rpf1
Postby Mr Alltrac » Thu Jun 12, 2014 1:34 am
Alright thanks, sorry offset is something I haven't been able to wrap my mind around yet.
Mr Alltrac
Re: Enkei rpf1
Postby underscore » Thu Jun 12, 2014 3:16 am
Use this http://rimsntires.com/specspro.jsp to play around with fitments, it helped me sort out offset. Spacers reduce the offset so some info from the wheel fitment thread + some playing around on the site will help you sort out what you need.
